Question about Iron Works Stainless Steel Gas Cooker (LP) Smoker
Gas cooker on boat
I have a 2ring gas cooker on a boat it is the old type one , i want to know how to clean jets on same as my kettle is getting a black stain on it thank you.
    Problem Solver:
  • 18 Answers
Generally, black soot stains mean the gas/air mix has too little air. If you have an adjustment for the air mix, open it up a bit. Also (don't laugh)- small spiders love to build cocoons inside these gas/air tubes. That really messes up your flame!
Posted on Jun 18, 2009
Can i replace the jets on cookmaster cooker to work on bottle gas
Bottled gas reqires a different gas nipple, most new hopbs come with a set. Note that in the UK you need a gas safe qualified engineer to fit gas appliences to the mains. Not sure about bottled gas appliances.
Aug 23, 2016 | Kitchen Ranges
Does anyone know how I can obtain a manual for a Masterbuilt Turkey Fryer & Seafood Kettle combo cooker?
Here's a manual for one of the older models. They are all fairly similar. Note the cleverly hidden reset button in the handle, most Masterbuilt fryers have one and frequently it is the only thing wrong!
https://www.appliancefactoryparts.com/content/pdfs/137637-1.pdf
Nov 27, 2015 | Masterbuilt Grilling
What is the correct fuel/oil mix 1977 25hp evinrude 2 stroke
50/1 500 ml to 25 litres 1 pint to 5 gal
Aug 30, 2014 | Boating
My russel hobbs jug kettle is leaking very badly and it's not 2 years old yet
Why would anything else fail because the kettle seal has gone? They are generally ok aren't they?
Apr 26, 2012 | Kitchen Appliances - Others
Aroma rice cooker ARC 978 - all control panel lights stay on when pluggged in. How do I reset??
Unplug the rice cooker and the remove the cooker kettle. Push the steel button in the center of the rice cooker to loosen the spring. Plug the rice cooker without the kettle, the cook function must not be functioning. Plug it again with the kettle and push the cook switch to see if it working properly.
Nov 08, 2010 | Aroma ARC7031G 6Cup Rice Cooker
My bass boat sat for about 8 months. I had it on the water this weekend and it was not idling well and had trouble starting. Once started, the boat ran well when i was in the throttle. I ran the old gas...
SOUNDS LIKE THE CARB LOW SPEED JETS ARE CLOGGED , THANKS TO THIS PITIFUL GAS WE GET TODAY ,I USE A ADDITIVE CALLED SEA FOAM IT WORKS GREAT JUST ADD TO FUEL EVEN WORKS FOR WINTER SET UP TOO
HOPE THIS HELPS
Aug 10, 2010 | Light Outboard Motor Boat Bass Fishing...
Gas trimmer runs for a few seconds and then stops
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 02, 2010 | Craftsman 25cc Gas Line Trimmer
My trimmer will start on choke but dies when you squeeze the trigger
depends on how old the trimmer is .. if its old then modern gas really messes with the fuel lines, primer bulbs and other rubber/plastic parts .. use only alcohol free gas in old equipment .. .. if its just a few years old then you may have a clogged high speed jet in the carburator or you could have bad gas (old) .. if its fresh gas then you have to clean or replace the main jet .. often you can remove the jet by removing the float chamber then a small filter . the jet is screwed inside a small hole usually in the center ... its tempting but dont use wire to clean out the jet .. if you scratch the jets precision holes then the mixture wont be accurate .. replair parts places often have a stock of jets .. also replacement carburators. to reduce the problem of jet clogging always drain fuel if the unit is not going to be used for awhile .. never try to use last years gas .. clean the tank once in a while .. and on old equipment dont use alcohol blended gas (most of todays gas) or replace all hoses filters and rubber parts with alcohol resistant versions .. (not easy to find)
Sep 19, 2009 | Ryobi Garden
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
May 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
Iron Works Stainless Steel Gas Cooker (LP) Smoker Logo
240 people viewed this question
Top Iron Works Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you an Iron Works Grilling Expert? Answer questions, earn points and help others
