Just picked up a Kitchen Aid Ultra Power Soft Start 7 Hand Mixer at a garage sale minus the beaters. Looking for the best place to get the beaters at the lowest cost ...
We sell the beaters at The Mending Shed, they are $8.95 for the set of beaters.
Here is a link to those on our website: http://www.mendingshed.com/kahandbeater.html
SOURCE: kitchen aid mixer
the unit sounds like the drive unit is stripped. if the planitary unit is spinning that gear is ok but the one below that is stripped. which is the one that spins the beater. Usually the professional lines are covered under a 2 year warranty. where as the others are a 1 year. I would contact kitchenaid first and see if your product is covered for replacement. they are really good about replacing faulty units. if not the unit can be repaired. It is a simple process and you can buy the parts off kitchenaid. usually the parts come with instructions as to how to replace them but if not repost to me and ill get you the directions on how to replace it.
SOURCE: spare beater
http://www.marbeck.com/mixers_kitchenaid_parts.html
heres link for replacement parts
my recommendations i would go with new parts but some will like to do the work them selves
SOURCE: Kitchen Aid flat beater leaves carbon on my hands and food
Are you using the white coated beaters or the burnished beaters. If they are the white coated beaters then the finish has come off and the zinc/underneath is rubbing off. Are you using the aluminum looking beaters in heavy acidic applications? if the mixer is new go to kitchaid customer support they will re-place. if your mixer is out of warranty then you need to replace it. about 15.00 t0 24.00 USD. if the problem persists then you may be leaking metal shavings from the planetary head, (I don't think it is happening but it is a possibility) if it is ground metal shavings you have a serious problem. I can't say anymore without knowing more. What application are you getting this result. is it all the time. is it after the mixer sits along time. need more info.
