Question about Initial DTV-322 32 in. TV/DVD Combo
Where is the sleep timer????
I've tried every menu I can find.... is it possible that there is NO sleep timer on a flat screen this new???? Also - my remote quit as well, even after a new battery. worked for a few more weeks then quit again. Is Initial known for crappy remotes?
  • 50 Answers
Just checked a similar sets owners manual...the sleep timer on this model is located in the menu---setup,,this menu prompt has language,SLEEP,menu trans,menu timeout ,and default setting....if you don't see the SLEEP mode in setup--you probably don't have it!...hope that helps
Posted on Mar 21, 2008
SOURCE:
How do I set sleep timer on the 6400?
Screen Menu > System > Time > Sleep Timer > TIME
This function automatically shuts off the TV after a preconfigured period of time. You can set the timer up to 180 minutes in 30 minute increments.
From: http://downloadcenter.samsung.com/content/UM/201308/20130813132610569/%5BENG_US%5DX12ATSCF-1.119.pdf
May 07, 2014 | Samsung Televison & Video
Set sleep timer menu on a SLED2490
turn sleep timer on and a section should light up
Jun 09, 2013 | Sansui 24" Widescreen Led 1080P Hdtv
How to fix sleep screen
Not sure what is meant by this question: if set has sleep timer it will be on the remote or in main menu.
If the set shuts off after turned on that is a different issue.
May 01, 2012 | TruTech PM1919BXA1 19 in. LCD TV
Does it have a sleep timer?
hello!
yes, it has the one! you need to go to the menu, setup portion of that. you'll see: clock set, timers, etc. That's where you will find it. A bit complicated, but possible. If your remote lacks "sleep" button, get the one with it.
good luck,
Alex.
Dec 09, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
Black screen and no sound after a few minutes.
First, here is a copy of your manual in case it is missing.
http://www.warrantyweek.com/library/ww20061219/panasonic-th42px60u-manual.pdf
Next, check the settings of the sleep timer.
Select on the remote:
Menu.
Timer.
Sleep.
See if there is a time setting in there. You may also find a shortcut from the remote labeled "Sleep".
If this fails to resolve the issue, you can always reset to factory defaults. To do this, select from the remote:
Menu.
Setup.
Reset.
Hope this helps. Be sure to let us know how this helped.
Jun 30, 2010 | Panasonic TH-42PX60U Television
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Dec 23, 2008 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Timer on television
The user manual is available here:
Pioneer website - PDP5060HD
Setting of the sleep timer is on page 58, quote:
You can also use the menu to set the Sleep Timer.
1 Press HOME MENU.
2 Select “Sleep Timer”. ( / then ENTER)
3 Select the desired time. ( / then ENTER)
4 Press HOME MENU to exit the menu.
Nov 17, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Initial DTV-322 32 in. TV/DVD Combo Logo
280 people viewed this question
Top Initial Televison & Video Experts
Steve Allison
Steve Allison
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
