Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Ultra Wash Quiet Guard 3 problem
At first I had this blinking light, after looking around the internet I found a solution via this site. I entered the control panel mode The sequence I used was: Hi Temp Wash, Heated Dry; Hi Temp Wash, Heated Dry. This did clear the blinking light and the dishwasher was able to be started, but now once it fills with water, nothing else happens. It just Hums and does nothing. What is this? Is there a pump that is burnt out? if so, what exactly needs to be replaced? Any ideas are welcome.
  • 7 more comments
  • Anonymous Dec 04, 2007
    I had the same problem Sears will not tell me the code to fix it they had to send me their technician and charge me $65.00 to push 2 buttons, which I was able to fix in 2 seconds after reading your web site.
    Thank you very much for your help.
  • willow_b May 11, 2008
    kenmore ultra wash Quiet Gaurd 3 the cleaning light wont go off and wont allow dish washer to run. prior to that the spinner on the top shelf wasn't working and dishes weren't getting cleaned.
  • gusha Jul 26, 2008
    normal wash light keeps blinking and we cannot start the cycle
  • charlie0420 Aug 19, 2008
    Dishwasher will not drain. I pulled it out and removed the drain hose that goes to the eleveated garbage disposal. When I took this off of the bottom of the machine the water drained out. When hit the cancel/drain button the pump can be heard but no water gets pumped out. ???
  • Anonymous Jan 31, 2009
    I had the same problem and looked up the solution right after my sister finished washing dishes ten people!! It worked right away. Thanks!
  • Anonymous Feb 06, 2009
    I had the same problem. Thanks for the code it worked!
    I had the same problem! Thanks for posting the solution, it worked!
  • charr711 Apr 26, 2009
    I had the blinking light problem which we cleared with your help and now it just fills with water but does not wash.. it will drain tho. any ideas?
  • sportgirl6 May 11, 2010
    Does anyone know the code?
Thanks Munkee,
I started having this problem, blinking green light,  three days ago with my Kenmore QG3 and finally was tired of not being able to use my dishwasher. I've had it for three years with no problems until 3 days ago. You solution, use of commands, really helped and no money wasted on tech assistance. Thanks again!!
Posted on Oct 10, 2008
Thank you sooooo much munkee!!! We had this problem awhile back and when I called Sears they gave me the code to correct the problem but I stupidly misplaced it and could not remember where I left it. You saved us! Thanks for your thoughtfulness.
Posted on Jun 05, 2008
  • tinman392 May 11, 2011
    I see this is an old problem. I wish I had read it before I tore everything apart. Once I got it all back together, I used the code.............it works great. Thanks for everything.
Code worked for me! I had to open and close the DW door and them pull out the machine and rock it a couple times. Now it is working. Thanks for the simple solution!
Posted on Sep 17, 2011
The quick rinse is blinking for two weeks now nothing turns it off, pulled it out to replace floor now what!
Posted on Mar 04, 2010
  • 51 Answers
Hi munkee, The fact you can hear the hum but no wash sounds like the main pump (motor) is stuck. The solution to this is to get to the motor impellor turn by hand and free up the rotation of the pump, and then put it back into the machine. If you are unable to free up the motor, then it is seized and a new motor will be required. Regards
Posted on Aug 21, 2007
Why is my kenmore ultra wash quiet guard blinking clean?
You can go to Kenmore's website, list your machine model and the
problem and you can get an answer. Usually you have to re-program
those machines every 400 hours. Hope this helps
Jul 06, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Why are there no lights on my Kenmore Ultra Wash Quiet Guard 3 dishwasher?
So I would guess you can't get it to work at all? It could be the circuit which is inside the door....I would never suggest anyone fix these things themselves. It's always fairly expensive but worth it for peace of mind knowing a job professional done.
Jun 25, 2014 | Kenmore 24 in. 15689 Built-in Dishwasher
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Nov 22, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Kenmore 24 in. 15932 Built-in Dishwasher Logo
7,497 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
