Question about Watches
The second hand on my luminox 8150 does not reset to 12 o'clock
The second hand on the chronometer stop watch does not reset to the 12 o'clock position when you reset the stop watch. How can I manually adjust back to the correct position?
  • 2,334 Answers
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Posted on Mar 23, 2009
  • chasmack Jun 04, 2011
    Perfect fix, for years I thought the watch was faulty!
    Thanks escapement.
On my new Victoronox 24332, the sweep hand for the stop watch does not reset to zero but rather to about 17 seconds past '12' O'clock. The split second hand also stops just past Zero on...
Follow the instructions on the following link. I believe it works on all or most Swiss quartz chronographs. Worked like a charm for my Mondaine and my Zodiac. Hope it works for you too.
http://mondainewatch.co.uk/my-chronometer-doesnt-go-to-zero.html
May 26, 2011 | Swiss Army Base Camp 24332 Watch
I just bought the armani ar0142 but the second hand doesn't work. Is this normal?
Take closer look and you will notice the small seconds hand which should be working. The dig seconds hand actually is chronometer hand and will work only when the chronometer function is engaged. Push the top button once=chronometer will start. Push the top button once more=chronometer will stop. Push the bottom button once=chronometer will return to zero. Rate me, please.
May 18, 2010 | Giorgio Armani Emporio Armani Black/Steel...
I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Mar 31, 2010 | Tag Heuer Link Automatic Chronometer...
Just got it out of the box. Second hand resets to 11:58 rather than 12:00 and the tenth of a second counter has a wobble in it and stops counting after 30 seconds.
to zero out the second hand pull the stem out to either the first or second position and then use the top and bottom butttons to zero it out. please rate my solution
Oct 10, 2009 | Luminox Navy Seal Divers #8352 Watch for...
I need to reset the hands
Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
On my watch I can adjust it by doing the following...
To reset the microseconds hand / top right
1) Pull the center knob full out (2 clicks)
2) Press the bottom push button to adjust the hand
To reset the seconds hand / middle
1) Pull the center knob a full out (2 clicks)
2) Press the top push button to adjust the hand
To reset the minutes hand / top left
1) Pull the center knob out half way (1 click)
2) Next press the bottom push button to adjust the hand.
Once all hands are reset, push the center knob back in fully...done
Mar 16, 2009 | Swatch Irony watch
Luminox 8152 chrono
If new, just take back and exchange it for another working one.
Sep 20, 2017 | Luminox Navy Seal Divers #8352 Watch for...
Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
Jul 25, 2008 | Tag Heuer Link Automatic Chronometer...
Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Jan 02, 2008 | Luminox Field 821 wristwatch
Watches Logo
1,308 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
