Question about GE PDW8200NWW / PDW8200NBB Dishwasher
Problem with my dishwasher not draining at all.....
So Im not sure If I have the air gap thing. casue I have a disposal and I have a spary hose aslso.. well like 4 days ago my dishwasher was fine. and then I ran a wash but I opened it to grab something out and then I did it again . and when the cycle was done I went to empty the dishwasher and there was water all on the bottum. well I scooped it all out . then I checked the kictchen drain hose and it was fine. then I ran another cycle.. oh I also blew into the hose that runs from the dishwasher to the sink thingy and nothing happened. so im confused please help .
  • MISSI79 Aug 22, 2007
    wow im confused. yes the dishwasher has drained before.... I moved into this home 3 months ago. and it just stopped draining. I have taken the thing apart and drained it and all kinds of things but still not draining.. Im gonna have to give you better details Im gonna go see exactly what I did . and then tell you
    Sniper:
  • 68 Answers
It sounds like you have connected your dishwasher to a garbage disposal.
Check to see that the drain hose runs through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then is connected to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
This should help you. If not please attach more info.
Please rate this solution
Posted on Aug 19, 2008
    New Friend:
  • 56 Answers
Has this Dishwasher ever drained at all? In installations the need to have a drain line attached to a disposal system is top on the list, how ever some times the connection is made but a small plug in the disposal on the inside of the wall of the grinding chamber has to be knocked out to allow for proper draining of the dishwasher water.
Posted on Aug 22, 2007
SOURCE:
MY GE DISHWASHER IS CONNECTED AND RUNNING, UNIT HA...
hi just try this Is the door open or unlatched?
Make sure the door is completely closed and latched.
Was the selected cycle interrupted before completing?
The Clean light will come on when the cycle is complete. Wait until the Clean light comes on before trying to manually drain dishwasher. Press Cancel/Drain to try and drain the standing water.
Is the water level just covering the pump module?
This is normal. A small amount of water will be seen in the bottom of the sump area at the base of the pump. This is to ensure that the pump seal does not dry out.
Is the dishwasher drain hose connected to a garbage disposal?
For many dishwashers, the drain hose is connected to the disposal and the knockout plug must be removed from the disposer inlet.
Is the drain system blocked?
Run the disposer to clear the drain system.
Do you have an air gap at your sink?
Check to see if the air gap is blocked by foreign material. To clean the drain air gap, follow the cleaning instructions provided by the manufacturer. With most types, you lift off the chrome cover, unscrew the plastic cap, and then check for any soil buildup. Clean if necessary.
Is there a loop in the drain hose less than 20" (50.8 cm) above the floor?
Make sure the drain hose is looped up so that it touches the underside of the counter before connecting to the sink drain or disposer.
Is there a kink in the drain hose?
Replace a kinked drain hose.
Did you reuse an existing drain hose?
Make sure to use the new drain hose that came with the dishwasher.
Is the sink drain clogged?
If the sink is not draining well, a plumber may need to be contacted. Most dishwashers connect to the sink drain. If the sink drain is clogged, the dishwasher can't pump out water.
Is the drain hose too long?
If the supplied drain hose was replaced with a longer one it must be shorter than 12' (3.7m).
May 17, 2010 | Dishwashers
Just replaced our disposal and now our dishwasher will not drain. Any suggestions?
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher will not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Dec 20, 2009 | Whirlpool Dishwashers
There is a horrible smell inside. We've taken the
cycle the dishwasher, and after it fills with water, dump 6 cups of bleach in there and let it contunue. just before it starts to drain, stop it and let it sit for an hour. restart dishwasher and let it cycle thru.
Oct 10, 2009 | Dishwashers
Air gap valve leak for dishwasher
remove the entire drain hose from the air gap and be sure it is clear, also the dishwasher drain should be going to your disposal, if you chose to use the air gap it should be connected from d/w to air gap then to disposal, todays dishwashers dont need an air gap.
Sep 12, 2009 | Dishwashers
Dishwasher (Kenmore 665 Ultra Wash) won't drain. Suggestions?
HI.This is a drain issue. check the following areas for faults.
1. Air gap / Drain hoses
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Ok, if the hoses are ok and not clogged, this will confirm a major issue that concerns the drain assembly or pump impeller.
replace the pump(drain) if found to be faulty.
Jul 20, 2009 | Kenmore 15899 Built-in Dishwasher
After isntallation my dishwasher doesn't drain correctly. What could be the cause of that? Is that possible that conected incorrectly? or may be have to program it?
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly. If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher. Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Jun 15, 2009 | Dishwashers
Once my dishwasher completed the cycle there is no water but after two or three days the bottom of the dishwasher fills with the dirty water. what could be the reason? I have garbage disposal and one pipe...
You must have your dishwasher connected directly to the garbage disposal and not through an air gap. What is happening is when you disposal fills with water it is siphoning through the drain hose back to the dishwasher. If you sink has a spare hole on the deck install air gap and run dishwasher drain through air gap first. Otherwise make sure you run Garbage disposal often so that water does not get slowed and build up inside.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
May 11, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Does not drain. Water stays in the bottom.
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Apr 13, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwasher does not drain completely, has standing water after every complete cycle.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. If you find suds in the dishwasher.
  • Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects.
    Please consult the Owner's Manual. Download a free copy of the Owners Manual and/or Installation Instructions. In the Installation Instructions, will be the procedure for removal of the drain plug. You may also check with the installer.
  • Be sure the kitchen sink drain is not clogged. The dishwasher typically drains into the kitchen sink drain or a garbage disposer. If the dishwasher drains into a garbage disposer, run the disposer to clear the drain system. Do not put hands into the garbage disposer. Serious injury could result. You should always turn on your garbage disposer prior to running the dishwasher to clean out any food or debris within the drain system.
  • Check drain hose where it connects below the sink for blockage or a kink in the hose. New dishwashers come with a white corrugated drain hose, which should be used. Re-using old, worn out drain hoses may promote kinking and blockage. If it is neccessary to extend the length of the corrugated drain hose, be sure the total length does not exceed 120 inches and the extention used is not kinked or crushed. See your dishwasher installation instructions for details.
  • Check the air gap if one is installed. It could be clogged. An air gap (not part of the dishwasher) is usually located on top of the sink. Some state or local plumbing codes require the use of an air gap between the built-in dishwasher and the drain system of the home. This plumbing device is used to prevent the possibility of back flow into the dishwasher in the event of a clogged drain system. This item is not a part of the dishwasher and, therefore, the dishwasher warranty does not cover costs related to cleaning or repairing a drain air gap.
  • Typical air gaps are easy to inspect and clean. Be sure the dishwasher latch is in the OFF position or unlatched prior to removal of the drain air gap cover. Simply lift off the cover (usually chrome, could plastic) and unscrew or unsnap (depending on type of air gap) the plastic cap below. Remove any material that may have accumulated and replace the plastic cap and chrome cover. This simple procedure should be followed any time the dishwasher fails to drain properly.
    View a short video about cleaning the air gap:
    Play Video
    Sometimes perceived "no drain" problems are not "no drain" problems at all, but back flow of water from the sink or some other device into the dishwasher:
  • If you notice dirty water building up over time in the bottom of the dishwasher and do not have an air gap, make sure you have a high drain loop. A high drain loop is created when the drain hose is makes a loop at least 18 inches above the floor. Usually this is accomplished by attaching the drain hose to the underside of the countertop. Without a high drain loop or air gap, dirty water from the sink can flow into the dishwasher. The high drain loop prevents back flow of water from the drain into the dishwasher if an air gap is not installed. View a short video about a high drain loop:
    Play Video
May 08, 2008 | Dishwashers
Diswasher airlock
By the airlock , you mean the air gap? .If the water is coming out of you air gap that means the hose that connects the air gap to your drain is clogged or your drain itself is clogged.Check the hose that connect the air gap to your drain(or disposer), check air gap and clogged disposer opening
Dec 01, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
GE PDW8200NWW / PDW8200NBB Dishwasher Logo
132 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
