Question about LG CED 8081BI CD-RW Burner
Stopped working without warning
I recently updated the RAM and installed USB 2.0 ports onto my HP Desktop which has an LG CD-RW drive which up until now was working perfectly well, it has since stopped working. Windows says the device is working properly, and when I put a disk in it tries to read it, however any disk I put in is shown to have 0kb of data on it and when I try to open the disk it is always empty. Windows has also told me that the drivers which are installed are the most up to date for the burner. Have I inadvertantly disconnected an important cable (there are 3 which I can see going into the drive at the back)or disturbed this device while installing other components... if so, does anyone know how I might repair the damage my clumsy fingers may have done? Thanks, K
    Sergeant:
  • 457 Answers
You might want to pull all the cables out of the LG CD-RW drive that is the ones you tampered with. No tampered sounds deliberate I meant connected. Start over again be a bit more careful noting what you were doing NOW opposed to then. Sometimes dust accumulated inside the machine gets into the sockets where you insert your cables "SOMETIMES" and at first things go well then suddenly cease. It cost nothing to try again and if you have already done this then perhaps it has jumpers to reset, check on google for those settings and hey goodluck sometimes thats the best solution.
Posted on Sep 01, 2007
SOURCE:
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
I have an HP DVD+R/RW 16x10x32x4x2.4x8x Drive and i am trying to find the drivers for it to see if it works on my computer. I have tried typing up the Product Number and HP Part Number on the HP website,...
DVD-RW 16X HP DVD Writer 740b Drive Firmware Update ftp://ftp.hp.com/pub/softlib/software7/COL16063/pv-42566-1/sp26595.exe
you must be logged in as the computers administrator to install this update
or
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&cc=us&dlc=en&lc=en
Update your HP desktop computer to have the latest software and drivers available. HP provides many software and driver updates free of charge
hope this will help you
  • You must be logged on as an administrator to install this update.
  • HP DVD Writer 740b drive.
  • Blank floppy diskette, recordable CD (CD-R), or USB Thumb Drive.
  • Released: s.gif 2006-08-23 Version: s.gif HI24 Compatibility: s.gif Microsoft Windows XP
    Aug 21, 2011 | HP/5.25 16x10x32x4x2.4X8x IDE Carbon...
    Where is the sound card located in a dell dimension 1100?
    The sound is integrated onto the motherboard in this model, it isn't a separate card.
    Jan 01, 2011 | Dell Dimension 1100 PC Desktop
    I have a HP External USB CD/DVD R/RW drive. Stopped working.
    First, try a new USB cable. Two, try a different USB port (if using a hub, directly connect to the computer). Three, check if there are any updated drivers or firmware for the drive.
    (also make sure that the external drive is self-powered that the cord is undamaged and the power isn't surging or going into a brown-out. If it is one of the new bus-powered DVD drives, make sure that the computer has a good power source (not on battery for a laptop).)
    Feb 27, 2010 | HP 8x External Double-Layer USB 2.0 DVD...
    HP pavilion desktop only has built in RJ45 connector--problem?
    If you have built in 10/100 RJ45 then any network connection is possible.
    One to one, you can connect to any built in 10/100 RJ45 equipped computer with a 'cross-over' network cable.
    More commonly you can connect to a 'router' which allows a number of computers to connect to each other and to the internet . Use a search engine to find net setup on the 'web.
    This is a very large subject so you need to decide what you want to do first!
    See
    http://www.computerhope.com/issues/ch000469.htm#04
    or
    http://compnetworking.about.com/cs/lanvlanwan/g/bldef_lan.htm
    or even
    http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
    Sep 12, 2009 | HP Pavilion Media Center TV Desktop with...
    LG DVD RW drive not detecting DVD/CD
    Start the Run Command Prompt
    Type in "regedit" without the parrenthesis then click ok
    Go to HKEY_LOCAL_MACHINE
    Then SYSTEM
    Then CURRENT CONTROL SET
    Then CONTROL
    Then CLASS
    Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
    The whole thing looks like this:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    Then delete the upper and lower filters.... (if lower filter is not there then leave it)
    RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
    Feb 02, 2009 | LG GSA-4082BI DVD±RW Burner
    I have a HP Pavilion a810n Desktop PC (AMD Athlon 64 3300+ Processor, 512 MB RAM, 160 GB Hard Drive, Dbl Layer 16X DVD+/-RW/CR-RW Drive, CD-ROM Drive) what back up ard drive is compatible
    do you mean an external drive for backing up your files ?... if so any usb external drive will work...of course larger then the hard drive you are backing up.
    Robert
    Jan 10, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
    DVD ROM/CD-RW Drive
    try to roll back the driver , if that doesn't work go to the manufactures web site and download the driver . if it still doesn't record install the drive in another computer and if it doesn't work then it maybe a bad drive itself
    Aug 06, 2008 | Gateway 310S (2900621) PC Desktop
    LG Combo Drive
    Try uninstalling the current driver, then applying the updated driver, worst case scenerio is you get the current driver again
    Jan 29, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
    External USB DVD-RW
    Hi Nick,
    this may be a driver conflict issue, either with your factory fitted drive.
    try going into system/device manager and see if its in there, click remove or uninstall, reboot and plug the drive in again, go through the add new hardware wizard if need be.
    the other suggestion, is to remove all USB devices from The device manager, reboot and the system will re-install the USB port drivers.
    Mike @ compurepair.
    Jan 17, 2008 | Computers & Internet
    Open Questions:
    See all LG CED 8081BI CD-RW Burner Questions
    LG CED 8081BI CD-RW Burner Logo
    37 people viewed this question
    Top LG Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
