Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Plz help me with my problem in my computer
Bios problem automatic shot down if i turn on my pc... Windows XP tnx.. nolly
    Brigadier General:
  • 6,966 Answers
Hi, Hardware wise this could be a memory issue. However, more often than not, it would be similar to a video problem that it either freezes or BSOD. Try reseating your mem sticks; OS wise, it may be corrupt drivers or XP startup files. Try to run in Safe Mode and check it if will load fully. If yes, you can start finding out anything out of the ordinary. If no also, then you may have to repair Windows; Virus wise, it may be that you have a virus or malicious software running at startup instructing your PC to shutdown. Try running in Safe Mode. If it will load, go to Start, Run, type "msconfig", Startup. Check all the programs that run at start up and uncheck those that you do not recognize. Reboot. If it will not run even in Safe Mode, you may need to reinstall/repair your Windows XP. Good luck and hope this be of some help to you.
Posted on Aug 21, 2007
SOURCE:
Shuttle xp, ntldr is missing
replace the cmos battery, reboot the computer go into bios reset date and time and change boot order cdrom to boot first save changes. boot from windows xp cd do a repair. form command type sfc /scannow checks all system files.if any are bad should repair them.
Apr 17, 2017 | Computers & Internet
When i plug my computer it will automatically open even i did not press the power and the bios boot post is not working i must press F2 or F1 to continue booting my computer
hi my name is rui
maybe your power botton is loose that why your pc turns on automatically. to fix your other problem go to bios setup then use the deffault settings on your cmos(Bios) if this doesn't fix it try changing the cmos battery, to change it open your pc and you will see a round battery inside just replace it then go to bios and use deffault setting agian.
pls. rate my comment tnx.
Jul 21, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Sir i m using windows 7 ultimate...n i want install tally 7.2. i cant use it in windows 7. i m also trying run as administrator, change compatibility mode in windows xp sp2 mode...but i hve same probs..so...
Tally 7.2 is not longer supported. You might need to upgrade to the newest version.
The only other suggestion is to see if you can run in XP Mode. This will depend upon your computer requirements.
Running Windows XP Mode requires:
1. Windows 7 Professional, Enterprise, or Ultimate editions.
2. A computer capable of hardware virtualization. This means your computer has a central processing unit (CPU) with either Intel-VT or AMD-V virtualization features.
3. Virtualization features turned on in your computer's basic input/output system (BIOS).
To determine whether your computer's CPU is capable of hardware virtualization, go to the Windows XP Mode and Windows Virtual PC support website and download a utility that can check whether your Intel or AMD CPU is compatible.
http://www.microsoft.com/windows/virtual-pc/support/configure-bios.aspx
To find your brand of processor so you can download the appropriate utility, click the Start button , right-click Computer, and then click Properties. Under System, next to Processor, you can see what type of CPU you have.
Even if your CPU can run Windows XP Mode, you might also need to turn on virtualization settings in your computer's BIOS. Procedures vary depending on the BIOS manufacturer. For more information, see BIOS: frequently asked questions.
http://windows.microsoft.com/en-us/windows7/BIOS-frequently-asked-questions
For more information, please logon to:
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7#section_3
Regards
Riztech
May 22, 2011 | HP Pavilion dv6000z Notebook
I have a hp pavilion a6030in pc with windows 7 coz it has some problem while video editing so i want to install windows xp but while formating a blue screen will appear every time so i cant format it. so...
the thing with this computer is it BIOS chip set setting are not configured to handle XP, you will have to enable it in the BIOS.
Problem with that if your BIOS will not allow XP to run, you will have to go back to HP or the motherboard maker and change the BIOS chipset.
hope this helps
Dec 21, 2010 | Computers & Internet
My hp pavilion a 1600n will not shut down unless done manually. When the computer restarts a message displays, "Active Desktop Recovery" with instructions on recovery. None of the suggestions work. A "0"...
try and repair the Operating system of your computer it will solve your problem or you can check all the running processes in the task manager must of time it do cause the system to slow.
Sep 01, 2009 | HP Pavilion a1600n (882780776265) PC...
Upgraded mem.now mon pc dont shut off fan con to run
Computer doesn’t power down when users shut down
In some cases, Windows XP’s Setup program can misidentify the power management scheme in a computer’s BIOS as Advanced Power Management (APM) instead of Advanced Configuration Power Interface (ACPI). When this happens, users will notice that the computer no longer automatically powers down when they shut down Windows XP. Instead, they’ll see the message It Is Now Safe To Turn Off Your Computer and be forced to manually press the power button to turn off the computer.
You can verify this problem by checking the power management configuration in two places—Device Manager and the Control Panel. To quickly access Device Manager, select Start | Run, type Devmgmt.msc in the Open text box, and click OK. When you see the Device Manager window, locate and open the System Devices item. If Setup identified the system as having an APM-compliant BIOS, it will be listed as a Standard PC in the System Devices tree. (If it were identified as having an ACPI-compliant BIOS, you would see it listed here as a Microsoft ACPI-Compliant System.)
To check the power management configuration in the Control Panel, open the Control Panel from the Start menu. If the system is using Category View, select Performance And Maintenance and then click the Power Options icon. If the system is using Classic View, just click the Power Options icon. If Setup identified the system as having an APM-compliant BIOS, you’ll see an APM tab in the Power Options Properties dialog box. (If the system were identified as having an ACPI-compliant BIOS, you wouldn’t see an APM tab.)
You may be able to fix this problem with a BIOS update. To begin, check with the computer manufacturer’s Web site to see if it’s providing the latest BIOS update. If you’re troubleshooting an off-brand computer, you may be on your own as far as tracking down the BIOS update. Here’s how.
Once you obtain and install the BIOS update according to the manufacturer’s instructions, you must perform what I call a Refresh Installation, in which you reinstall Windows XP on top of an existing Windows XP installation. You must perform this reinstall operation because the power management features are tied to a special power management Hardware Abstraction Layer (HAL). During the Refresh Installation procedure, Setup will completely redetect all installed hardware, including the updated BIOS, and rebuild the power management HAL as well as the part of the registry in which information about the installed hardware is stored.
Jul 20, 2009 | Gateway M280E
New compaq 6830s won't turn off
problem is really amazing.......hmmm i think its auto start by your bios.... just see is there any option in the startup option for your bios
Mar 29, 2009 | HP Compaq 6830s Notebook PC
Automatically retarting when I shut down computer
2000 Is Windows 2000. Why did you put that disk in? Did you start loading Windows 2000 or XP Pro, XP-Home?
It sounds like your switch is wired to the reset jumper on the motherboard or you are hitting reset.
Tell me what the computer screen has on it before it shuts down please.
I will wait on you answer. Do not rate until we are done.
Jun 10, 2008 | Computers & Internet
Windows32
pls plz update ur antivirus...now u have to get the updates of ur antivirus....use mcafee 5200engine of 8.5i version...its an free download...from mcafee website...n download superdat update files...n after getting new antivirus....re install windows...then install mcafee then its updates...tats it..
virus entries wil come due to use of pen drives...so b alert..
ne other prob's do tell me..N plz plz do rate me
cya
Apr 15, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
