Question about Southwestern Bell GH5850 Cordless Phone
Caller ID screen is messed up
The caller ID screen on my handset does not display complete characters. Many of the dots and lines will not display in various spots on the screen making it virtually impossible to read. The same thing happened to my GH58 add on handset but is not as severe, and also to a VTech phone located in the house also. I assume I am correct in guessing that nothing can be done about this?
  • ricardami Aug 16, 2008
    I just put NEW batteries into my 2 phones and they both still have the same problem. Partial display--letters and numbers .Sections of letters and numbers are missing making it impossible to read.
Are the batteries alright in the phones?
Posted on Aug 21, 2007
HOW DO I SAVE AN INCOMING NUMBER ON KX-TG6812e
Storing a number in the phone book with the KX-TG6812 from the Caller ID list is shown in the manual. WIth all handsets in standby mode, press the Down/Caller List button on the navigator key circle on one handset. Press the down or up arrows to navigate to the number that you want to add to the phone book. Press the right soft key (the LCD screen above the button should be displaying a rectangle with 6 squares). Use the Up/Down arrows to highlight Save CID. Press OK. Use the Up/Down arrows to select Phonebook and press OK. Enter the name of the caller (up to 16 characters). Press the appropriate number key multiple times to display the desired character. Use the * key to switch from upper or lower case. Press the left or right arrows to go to add the next character in the name. If you need to use one of the different character tables, press R/Eco (below the # symbol). Press OK when finished. Press the Call End/Off button to exit the menu.
The manual is available on the product page: https://www.panasonic.com/africa/consumer/telephones-home-security/telephone/cordless/kx-tg6812.html . Scroll down to the bottom of the page or click on the Support link. The direct link to the manual is currently http://www.panasonic.ae/EN/Manuals/KX-TG6812.pdf . You need the information from page 35 to store the number and page 21 to add the caller name to the entry. See page 45 for the extended character tables and the character/number tables.
I hope this helps.
Jul 08, 2018 | Lands Phones
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Why doesn't the LCD display doesn't work?
Does the LCD not work at all? or do you mean that it doesn't display Caller ID information? If the LCD is completely dead, you'll need to get the phone repaired. On the other hand, if it's just the Caller ID that's on the fritz, try this: unplug the base from the power socket; remove any batteries in both the base and the handset; wait one minute; plug the base back into the wall and replace all batteries. This will reset the Caller ID so it works again. (Depending on the phone you may or may not lose settings and memorized numbers.) If this doesn't help, the problem will require a professional repair.
Aug 06, 2014 | Uniden D3097 LOUD & CLEAR Cordless Phone -...
How do you turn off talking caller ID on panasonic kx-tg4032?
This feature lets you know who is calling
without looking at the display.
To use this feature, you must:
- subscribe to a Caller ID service of
your service provider/telephone
company.
- turn this feature on (page 24).
When caller information is received, the
handsets and base unit announce the
caller's name or phone number received
from your service provider/telephone
company following every ring.
The unit announces in English only.
L Name pronunciation may vary. This
feature may not pronounce all names
correctly.
L Caller ID service has a limit of how
many characters can be displayed. If
the caller's name is too long, the
handset may not be able to display or
announce the entire name.
L The announcement is heard at the
same level as the ringer volume (page
16, 23).
L If you turn on the answering system
and set the number of rings "2
rings" (page 36), the unit does not
announce the caller information. If
"Toll saver" is selected and there
is a new message, the unit does not
Mar 24, 2011 | Panasonic KX TG4032 19 GHz Twin Cordless...
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Caller Id not working KX-TG6323PK
Don't mind. Returned the product to the seller. Thanks.
Jan 11, 2009 | Panasonic KX-TG6323 1.9 GHz Trio 1-Line...
No caller id on my phone
no caller id on my phone
Nov 11, 2008 | Uniden Cordless Phone
Round button in middle quits working.
Sounds like you may not be selecting the right menu buttom. The soft keys are right below the screen. these three buttons function change depending on which screen you are viewing. I have copied the instructions from the manual below. You must select phonebook to view the phone book using the round button. You must select volume to change the volume with the round button.
The Standby Screen
When the phone is in standby, the handset display shows the following items:
Handset
Ringer off icon (when the ringer is off)/ day of the week and time / battery iconHandset ID and BannerNumber of new Caller ID calls received (If there are no new Caller ID messages, the Handset ID appears here.) SUN 12:00A Handset #1 New CID: 5REDIALMENU
Using the Four-way Function Key
Your handset has a four-way function key that allows you to move the cursor (or highlighted area) on the display and access the most commonly used features at the touch of a button. By moving this key to the left, you open the Phonebook. Move the key to the right to access Caller ID information. To use this four-way key, place your thumb over the key on the station and move to the four positions to get the feel of how it moves and operates.
Using the Handset Menu
To open the menu, press the MENU soft key. Highlight the option you want by pressing the four-way function key. This will move the cursor; the option currently highlighted appears in reversed out text. Select the highlighted option by pressing the OK soft key. To exit the menu and return to standby, press [].
If you do not press a key within 30 seconds, the phone will time out and exit the menu. When setting Date and Time, the time-out period is extended to two minutes.
Note: For GLOBAL SETUP and DEREGISTRATION menu options, make sure the line is not in use and the handsets are within range of the base. 123abcdefView the phonebook Four-way Function KeyUpView the Caller IDDown123abcdefView •
Jan 31, 2008 | Uniden TRU9480 Cordless Telephone
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Oct 23, 2007 | GE 28111 Cordless Phone
Southwestern Bell GH5850 Cordless Phone Logo
316 people viewed this question
Top Southwestern Bell Lands Phones Experts
Hollyecho Montgomery
Andrew Taylor
Andrew Taylor
Are you a Southwestern Bell Lands Phone Expert? Answer questions, earn points and help others
