Question about Frigidaire FRS23H7CS Side by Side Refrigerator
FRIGIDAIRE M.N. FRS26R4CWR AND S.N. LA52921475 ICE MAKER GSI-26
THE REGULATOR ON MY ICE MAKER IS FILLING TO MUCH WATER INTO THE TRAY AND THE ICE ARE NOT COMING OUT INDIVIDUAL BUT ALL IN A LARGE LINE. IN OTHER WORDS THEY ARE NOT SPLITING UP. I CANNOT LOCATE THE REGULATOR TO LIMIT THE AMOUNT OF WATER THAT IS COMING INTO THE ICEMAKER. CAN YOU HELP ME? THANK YOU IN ADVANCE FOR YOUR HELP P. HENRY
  • Anonymous Dec 01, 2007
    Icemaker started to overflow on head side, not a lot, just enough for a mess, ice does not seperate and tends to make double cubes most times, I remove from freezer and clean weekly. irritating but sometimes it works longer than a week.
  • Anonymous Mar 29, 2014
    ice maker not working
  • 291 Answers
Is this the original ice maker? If it is you should be able to pull off front cap on icemaker head and see a adjustment screw with a - and + signs adjust towards - tell required level is reached.. most new model icemaker have NO adjustments.. has a circuit board for a brain..lol and takes care of the adjustments
Posted on Aug 21, 2007
  • Mike Johnson
    Mike Johnson Aug 21, 2007
    here is a pic of original icemaker for that model
Ice maker does not make ice at all
Posted on Feb 22, 2010
I have a Frigidaire Model# FRS26H5ASB9. The ice maker is a GSI-26. The ice maker water line freezes up and then the ice maker does not work. It goes thru the cycle and it sounds like it is filling but no...
The most likely reason for this happening is a defective Click Here=> 241734301 Triple Water Control Valve These valves are located on rear of refrigerator and near floor where the water supply enters your Refrigerator. CLICK HERE=> FRS26H5ASB9 USE AND CARE GUIDE
The valve location is listed on page 5 of the Use and Care Guide, If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) This problem is typical as a leaky faucet that drips even when the water valve is turned off. I will be here to answer any questions you may have, Thanks Sea Breeze
If helpful please rate this solution, Thank You
Jul 16, 2011 | Frigidaire FRS26H5AS Side by Side...
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
Currently the water is leaking from the ice maker. there is ice build up in the control box its self, and its leaking from there. No sure how the water is getting in tot he control box itself so i'm...
You are right - it is filling up with too much water. If you remove the front panel of ice maker you will find a screw there that adjusts the length of time that the solenoid stays open to admit water. Turn it counter clockwise to reduce the time and amount of water entering the ice maker.
If you need new maker get them cheap on ebay. eBayeBay
Sep 08, 2017 | Frigidaire FRS23H7CS Side by Side...
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
Frigidaire side by side model:FRS26HF6BW2
Check the trap door where the ice drops through, it might be stuck in the open position, solenoid that operates the door may be bad.
Jan 27, 2009 | Frigidaire FRS26R4A Side by Side...
Ice not dropping
Press the little button on the bottom right of the ice maker and clear the tray of ice. The maker has to be turned on for the tray to tilt and empty. This corrected the problem for me. The freezer side may have been left open and and the ice maker filled the tray while the door was open, I suspect.
Nov 12, 2008 | LG LRSC26940ST 36" Side-by-Side...
Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Jul 13, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
No water in ice maker
The ice maker itself sounds like its not calling for water, you would need to replace ice maker, not field servicable. did you switch the solenoid? or the wire(s) leading to solenoid??? by switch the wire(s) when you depress for water the ice tray will fill with water. reason i say that is possible that the solenoid is energized, perhaps the valve post its sitting on is no good
Mar 11, 2008 | Frigidaire FRS26F4C Side by Side...
Frigidaire FRS23H7CS Side by Side Refrigerator Logo
2,384 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
