Question about Panasonic PV-GS19 Mini DV Digital Camcorder
Recording from your TV?!?!
I need help using this video camera to record off of my tv. I know other cameras can do that by hooking up the A/V cables to A/V out on the back of the TV. Now I need to know if there was a certain setting on the video camera which could let me record off of it. Please can someone help me on this??? Thanks.
    Champion:
  • 217 Answers
A/V in is different from A/V out. You cannot record tv in the camera if it has no a/v in
Posted on Sep 01, 2007
SOURCE:
I have a DVD/VCR recording device and I need to hook up my camcorder to record videos to a DVD to submit to an organization for my son to receive a service dog. I can hook up camcorder straight to TV...
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
See page 21 of the manual for the GR-D347U. Treat the DVD recorder as a VCR for this situation. The manual is available here: https://www.manualslib.com/manual/82266/Jvc-Gr-D347u.html?page=21#manual .
I hope this helps. Please add a comment with the details of the DVD recorder for more information on connecting the unit in this daisy chain.
(Many recorders have at least two composite video Line In inputs. That's why you need select the correct one for recording.)
May 19, 2017 | JVC GR-D347U Camcorder
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
CANNOT GET TO TRANSFER MY VIDEO FROM MY CASETTE CAMCORDER TO THE COMPUTER USING MY 4POINT FIRE WIRE CABLE,THEY SAID I CAN USE THE ADOPTER AND THE FIRE WIRE CABLE IF I DON'T HAVE THE JACK FOR THE IEEE 1394...
you will need to hook your camera up to the fire wire to transfer itto the converter so connet the firewire to the camera and hit the play button however I don't know if your converter has a program that finalizes the video once your done recording. On some camera's it will finalize the DV and then it is the only thing you can use to transfer to the DV converter or to your computer, let me know what type of camera you have and I can tell you how to connect it to do it.
May 05, 2010 | Canopus ADVC-110 A/D Converter...
Connecting and recording camera with s video output on 1221 tx
The cam setup you're trying in your surgery is similar to the type I often setup in Dental operatories for there intra-oral cameras.
You need an tuner, if your external has S-Video port, you can simply plug into it and use windows media center or the cards software(if it came seperate) to record from the s-video feed.
Then you can hook the S-Video output from the laptop to the TV monitor in question and run the laptop in mirrored mode to show the same image on both screens.
Hope this helps,
Chris
May 26, 2009 | HP Pavilion dv6000z Notebook
When I plug in my camcorder to the tv using the AV cable and select the correct tv input, the picture does not display on the tv and there is a trememdous amount of feedback.
I connect my camcorder to the TV with regular RCA plugs (yellow, white, red). The camera RCA plug-in holes are in a separate compartment. I can see what I am recording on the TV if the camera power switch is pushed over to "camera". I do my recording. Rewind. Then I have to push the power switch to "off" then over to "VCR" , and push "play" on the camera in order to see the play back on the TV screen. See if your power switch has several positions. I hope this info. is helpful.
May 17, 2009 | JVC Everio GZ-MG335 HDD Camcorder
Your laptop has Tv Tuner card and if it takes TV input via cable , you get a S-Video / DVD cable to regular cable converter and use the laptop as a video recorder - if you are in US , any Radio Shack will be able to help you with the cables
May 17, 2009 | HP Pavilion dv6000z Notebook
I hooked up my sony handycam to my dvd recorder & recorded it on a dvd. While it was recording it had sound (hooked up to the tv) but the recorded dvd does not have any sound.
your dvd recorder should be compatible with dolby digital 5.1 surround sound because that what camcorder uses. you can try to switch audio recording on camcorder to stereo.
Apr 21, 2009 | Sony Handycam DCR-SR40 Camcorder
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Need to watch recording on tv
If your camera has audio vidio cable (just get a cheap one which has a yellow, red and white connector) connectors. simply plug them in the audio vidio out on camera and audio vidio in on TV and thats it.
Let me know what type of connectors you have on your camera?
THanks
Dec 07, 2007 | Sony Handycam CCD-TRV107E Camcorder
Panasonic PV-GS19 Mini DV Digital Camcorder Logo
48 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
