Question about Bose Wave Radio
AWR1-1W Bose buttons are not working properly after running on low power. Can this be fixed?
The radio was plugged into an outlet that was wired to a dimmer switch and it ran for several hours on the lowest (dimmest) setting... now the buttons won't work. The screen will show strange configurations when you plug it in... the last time it said "F:01" and now it says ":01" and "alarm." This is the version with the 9v battery. Any suggestions?
SOURCE:
  • 6 Answers
SOURCE: Bose AWR1-1W older version, not Series III, no power, pop when unplugged.
I've got a simillar problem... will be looking into it this weekend. U402 is supposed to be the 5Volt regulator.
The input to U402 is U401 its a 12Volt regulator.
You should check both...
Posted on Apr 04, 2008
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
SOURCE: bose radio won't turn on
My Bose wave radio (w/cd ) was purchased in 1999, it was working fine untill it quit. Power is gone. What could be the cause and how could i fix it or can it still be fixed?
Posted on Nov 08, 2008
SOURCE: Bose radio display doesn't show at all
I just posted a similar problem and did 2 more minutes of research on this site to figure it out. Hold down the 'cd mode' and press the on/off button. This turns the display on or off.
Posted on Apr 28, 2009
DigidocTN
  • 22 Answers
SOURCE: 120v Bose Wave Radio/CD player plugged into 240V outlet
There is a fuse you can check. Also a rectifier bridge, a 3 terminal regulator IC (18V in, and 10V out) as well as a small transistor Q1 which often shorts. Easy and cheap fixes, or I would offer to buy your non-working model Bose if you decide to sell it.
Posted on Jun 30, 2009
Appliances plugged into the mains cause interference in the fm signal which means radio off if appliances in use. Also interference if Bose iPod plugged into mains next to radio.
You can buy an AC line conditioner, they range from cheap and useless to expensive and exotic, which is able to filter interference coming over the power lines. Simply plug that into the wall, and your radio into the filter, and there should be an improvement.
You can also try plugging the radio into a different outlet, making sure the outlets are wired properly, and try moving the radio to a new location further away from the source(s) of interference.
Don Miller, CET
Private Bose Radio Repair Service
don.miller60@outlook.comJ5QKPK
Nov 23, 2015 | Bose Wave Radio
Bose will not tune and no sound
First make sure you haven't selected Aux or CD by mistake. Push the Radio button on the remote and try to tune. If that doesn't work, try unplugging the power cord. Wait 10 seconds, then plug it back in. This resets the system, which may fix your problem.
Sep 01, 2014 | Bose Wave Radio
I have (7) 20W bulbs on a newly wired line running on a brand new 200W Malibu transformer, worked fine for 2 days and now it's tripping the reset button - Any suggestions ??
1) Copy following link for malibu power pack tips for longer transformer life:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Two plug choices on each outlet, Plug power pack into other outlet on receptacle.
Inspect for damage on outdoor outlet.
Replace outdoor outlet, and do not use quick connects. Connect wire directly to screws on side of device.
Replace GFCI outlet.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 01, 2013 | Malibu Intermatic Inc. ML121RT Low...
I plugged my radio into a plug on a dimmer. Now my radio won't come on at all. Did I fry the power supply?
Have you tried plugging it back into a regular outlet. The dimmer would not allow enough power through to power the radio and shouldn't have fried the power supply but I could be wrong
Apr 26, 2011 | Bose Wave Radio
When I plug my Bose clock radio into one outlet, I get nothing but static. When I plug it into a nearby outlet (with out really moving the cord), I get perfect reception. The problem is the outlet where...
The Wave Radio uses the AC power cord as an antenna. Perhaps the two outlets are wired differently regarding ground and hot.
An interesting article...
http://www.gcaudio.com/resources/howtos/acpolarity.html
As the man says in the article thecircuit tester like this...
http://www.idealindustries.com/products/test_measurement/electrical_testers/circuit_tester_e-z_check.jsp
... can be found at many Dollar Stores for cheap.
Mar 06, 2011 | Bose Wave Radio
Bose Wave unplugged now it won't power up when plugged back in
I will first start check the power section circuitry of your Bose Wave radio. Are you electronics savvy?
Jun 16, 2009 | Bose Wave Radio
Can a Bose radio get fixed after a power surge?
YES IT CAN UNPLUG THE RADIO ..OPEN IT UP LOOK @ WERE THE POWER CORD COMES INTO THE RADIO SEE HOW BAD IT IS >>>IF IT IS ALL BURNT UP YOU HAVE TO GET AN IDEAR HOW MUCH A REPAIR PLACE WILL WANT>>>>>>>>BUT IT MAY ONLY BE A FUSE IN SIDE YOU MAY GET LUCKY>>>>>>>>>YOU CAN EVEN FIX THAT YOUR SELF WITH A SOLDERING IRON FROM RADIO SHACK OPEN IT UP SEE WHATS GOING ON IN SIDE MAKE SURE POWER IS UP PLUGGED GOOD LUCK
Feb 20, 2009 | Bose Wave Radio
there is a fuse inside but after changing the fuse if it still dont work the rectifier could be bad.
Jan 13, 2009 | Bose Wave Radio
Bose radio won't turn on
May 03, 2008 | Bose Wave Radio
Bose Wave Clock Radio
Considering all power is good, check for broken or fractured solder joints at interconnects between display and main PCB on BWR-I.
Check cold solder joints on U302 and U301(IC302, IC301).
Good Luck.
Dec 21, 2007 | Bose Wave Radio
Bose Wave Radio Logo
199 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
