Question about Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds)
Mpc4000 Hi, there is no power to my mpc4000,i have tryed another two x fuses and plugs, nopower what so ever
  • Anonymous Dec 29, 2008
    I have the same problem but everytime i put a new fuse in it blows! I replaced the Power Filter and The Power switch and circuit boards and still does the same thing any answers?
Hi, I had the same problem as deano12. No power on my MPC 4000. I fixed the problem myself for £2.49p! and it's a very easy DIY job, trust me..... Now its as good as new.
Here's how it's done:
Tools = Small posy screw driver.
Allen Key
#1 You will need to buy the following (T 2.5A 250V) fuse. You can get this from Maplin the code is GL63 and it's £2.49 for a pack of 10, but you will only need one.
Note: This fuse does not go in the plug, but is located inside the MPC on the left hand side next to the side panel. There is only one so you shouldn't miss it.
#2 Follow the link below to the MPC4000 service manual and follow the diagram instructions on how to dismantle you machine. This is just unscrewing about 30 small screws.
http://www.woralelandia.com/openmpc/files/MPC4000_Service_Manual.pdf
#3 Locate the fuse, take it out and replace it with a new one.
If your having trouble finding it, look on page 7 of the service manual and it's just behind the PC FILTER BLK.
#4 Follow the steps you took to dismantle it but in reverse.
Goodluck and have faith!
Ali
Posted on Apr 12, 2008
    Novelist:
  • 231 Answers
Hi, have you tried a diferent power point {wall outlet], If all else fails you will need to test the internal power pack, If you can use a multimeter then the red wires are 6v, yellow wires 12v, black = negative, blue 5v grey is neutral and purple is 2v. If you cant do this then its off to your nearest technician. Goodluck, regards mistyman
Posted on Aug 21, 2007
SOURCE:
No power to master swicth pink yellow wire checked ignition sw there's no power coming from there at all ck breaker ok there's nopower reaching master sw if I supply power there windows work any answer
Pull the power window circuit breaker, and with key in ON, check the terminals for the circuit breaker. One of the terminals where breaker plugs into should have battery voltage with key on. If it does, there is probably a break in the wire from the circuit breaker to the master switch- probably in the door opening.
If the breaker does not show power, you will have to figure out why the ignition switch does not send power to that portion of the fuse panel, including that breaker. That portion would be designated as "hot in run or start". There would be several fuses like that. May need a wiring diagram- on some, the hot wire from the switch trips a relay which sends power to that portion of the fuse panel. On others, there is simply a hot "run" wire that powers up some of the fuse panel.
Jan 03, 2015 | Cars & Trucks
Has no power inside no dash lights 1995 nissan 240 sx
check the fuses under the hood I seen this exact same thing happen to a friends 95 Honda prelude and it blew a fuse
hope this helps
Aug 30, 2014 | 1995 Nissan 240SX
Turn on key ,nothing no power
Check Battery cables to see if they're loose.
Check fuses if it's just lights.
Jan 16, 2014 | ATVs
1996 fiesta ghia diesal no glow plug light
No power to the glow plugs means no power to the light also. You have a bad fuse or connection to the glow plug relay. Fix that and your good to go. Has nothing to do with your indicator lights on either side of dash. Glow Plug power indicator is labeled THAT and only that.
Jun 25, 2017 | 2000 Ford Focus
No power to interior lights, nopower to the radio, no power to the trunk, all amp fuses are not broken please respond.
conv, coupe, sedan? engine size????????? which lights, what in the trunk has no power????? which radio wih amp/ without amp/ cd???? which fuses have you checked, how did you ck them? are they getting power or not? ck fuses 20 22 23. if number 23 has no power ck ignition switch.
Sep 18, 2009 | 2004 Chrysler Sebring
Nopower to radio on my suzuki grand vitara. any
if you connected it right, I mean red to red, yellow to yellow and black to black. check the fuse thats leading to the radio, and check the fuse in the fuse box in the car, if thats ok then just put the yellow and red from the radio together with the red one from the car, the only problem with that is that you'll have to turn your radio off every time you leave your car. don't forget, it will drain your battery
Jun 20, 2009 | Car Audio & Video
No power
check ignition and ground maybe even double up ur ground
May 18, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
1993 Jeep Grand Cherokee Laredo Break Light Sensor
check the brake switch located on a bracket under your driver side, on top of the brake pedel check for power, if power depress on your pedal see if there's nopower on the other side of the switch then replace the switch. I think it is the switch.
Mar 08, 2009 | 1993 Jeep Grand Cherokee
Nopower
armature winds bad??? how old is unit ,maybe just brushes are bad
Jan 13, 2009 | Welding Tools
Computers & Internet Logo
358 people viewed this question
Top Akai Computers & Internet Experts
Marvin
Marvin
Alun Cox
Larry Ng
Larry Ng
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
