Question about Kenwood KDC-MPV8025 CD Player
Kenwood KDC-MP825 car stereo problem
I have a Kenwood KDC-MP825 car stereo. After 3 years of trouble free performance, it is now malfunctioning. When it powers on, the lower panel flips down as normal and begins to operate normally but after 2 seconds, it retracts to a 45 degree angle and the entire panel assembly starts to retract in power off mode then it stops halfway in, powers off and is completely non-responsive. It does respond to resets, but a few power ups after reset, the same problem occurs. I've read about faulty data ribbons and also dirty panel contacts - I hope this is fixable because I love this unit!
  • 4 more comments
  • vince9985 Dec 23, 2007
    i have the same problem, its such a swet radio that i want to fix it, same thing happens to me have you fixed yours?
  • Anonymous Jan 08, 2008
    I have had the exact same problem at the three year mark. Looking for fix if anybody had a solution.
  • courtenay Apr 15, 2008
    I've got the same problem after about 3.5 years. Its start time coincided with the beginning of the cold winter weather toward the end of 2007 and seems to **** out in the morning more frequently after a cold night. Mine starts with the ignition and opens the faceplate like it should but then powers off and just sits there, open. It will eventually respond to multiple pressings (long and short) of the standby button but the length of time to get it working is hit or miss and very annoying.
    I haven't had the opportunity to take it out, check the connections and put it back in but I'm hoping this is fixable because like everyone else says, it has been a very nice head unit.
  • remmiz Apr 19, 2008
    same problem here...I think it has something to do with a sensor and the opening motor as mine started doing this after someone accidently knocked the flip-out panel pretty hard.
  • fixmykenwood Sep 06, 2008
    my kenwood has done the same thing at around the same time (3.5 year mark). Does anyone have the answer to how to fix it?
  • Anonymous Dec 06, 2008
    Looks like I will have to join this same reason why everyone's here.
    I've had the unit installed and working in 3 different cars. Now the deck acts up as the description above. This took place in my gf's car. I have taken out the cd player and inspected all connections without any problem. So my wild guess was probably the face plate was moved out of it's ribbon sensor's limitation. It would be nice to be able to reset the ribbon back to the correct place, which will most likely fix the shutoff of the unit when it senses the faceplate is being stopped from opening.
  • 3 Answers
My wife experienced the same problem this month, December 2008, after owning the KDC-MP825 for 3.5 years (what's up with that?). It would power on briefly, the panel would move, then after 2 seconds it would shut down. After 15 seconds, it would power again, panel motors whir, then shut down. It would keep doing that while the key is in ignition.
This appeared to have solved the problem:
Hold down BUTTON [5], press the RESET button (you'll need a ballpen to press between the AUTO and SCRL button).
This was the procedure for getting the receiver out of demonstration mode. Maybe the cold weather here in New Jersey placed the unit into demo mode?
Posted on Dec 08, 2008
SOURCE:
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
When i power it on it shuts off i got a kenwood kdc-mp825
Disconnect all of your speaker leads at the head unit, make sure none are touching, then power it back on. If it still cuts out, check your ground, if it doesn't, re-connect speakers one by one and test power again. It will either cut out when you get to a speaker or wire that's shorted, or work just fine. it's protecting itself from damage by cutting off when speakers are either bad or have shorted wiring. Most common shorted wiring happens on door speakers at the hinge. If it continues to cut off without speakers connected and you have a good ground, the unit needs service. If it still plays and you find the speaker or wire that's causing the problem, disconnect the wire at the speaker and test again, if it works, replace the speaker, if it doesn't, replace the wire. Hope this helps
Jul 07, 2011 | Kenwood Sirius KDC-MP825 CD Player
Don't have an owners manual for a KDC-PS900 kenwood car stereo
You can get the mnanual on the link below.
http://www.usersmanualguide.com/kenwood/car_entertainment/kdc-ps900
Good Luch and please rate 4 thumbs up for the free answer
Aug 21, 2010 | Kenwood Car Audio & Video
Free unlocking code for kdc w3037a
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Oct 29, 2009 | Kenwood KDC-W3037A CD-receiver,...
Kenwood kdc-mp5032. cannot play car stereo. unit requires code when powered up. current known code doesnt work.
Unfortunatel KENWOOD codes are not available for free from anywhere on the Internet.
Main Dealer or a Decoding Service only
Sep 01, 2009 | Kenwood KDC-MP5032 - Car Audio CD MP3...
Unlock code
This is the only way to clear the code. You must have the remote to do this, it will not work without the remote. I work at an authorized Kenwood service center and tell you for certain that this is the only way it can be done. If you do not have a remote, you will either need to buy one or borrow one from somebody else who has a Kenwood radio. Most all Kenwood car stereo remotes will work, it does not need to be from the same model number but it must be a Kenwood car stereo remote. If you can not find a remote for this then you will need to take the radio to an authorized Kenwood service center and they will usually do it for a small fee.
The first step is the only part of this procedure that you do not use the remote.
1. During code request mode, press the Track UP key for at
least 3 seconds while holding down the AUTO key. (– – – –
will disappear)
2. Enter, “KCAR” with the remote controller as described below.
• Press the remote controller 5 key twice, and press the Track
Up key. (Enters a “K” )
• Press the remote controller 2 key three times, and press
the Track Up key. (Enters a “C” )
• Press the remote controller 2 key once, and press the Track
Up key. (Enters an “A” )
• Press the remote controller 7 key twice, and press the Track
Up key. (Enters an “R” )
3. Security function is canceled and unit sets to All-Off mode.
4. Code request mode appears if a mistake was made in entering
the numbers.
Dec 09, 2008 | Kenwood KDC-MP228 CD Player
Kenwood kdc-mp 825
it's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Sep 06, 2008 | Kenwood KDC-MP828 CD Player
KENWOOD KDC-1020 user manual desperately need a user manual for my wife thank you
Mate go here http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man the kdc 1023 manual is the same and its a free PDF download :)
Mar 08, 2008 | Kenwood KDC-2025 CD Player
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
Kenwood KDC-MPV8025 CD Player Logo
727 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
