posted by macaddyac1 on Aug 20, 2007
My CPU is about two years old. I have had no problems with it until now. 2 problems have happened at the same time. The first is my wireless card went bad. I know how to fix that problem. The one I can't fix is the screen is flashig white light across it. I can't view what is happen on the screen anymore. The CPU seems to be working fine but the screen is showing nothing but those lights.
Solution #1
posted on Aug 21, 2007
To confirm that indeed you laptop CPU is working normally, you can try plugging an external monitor. This will also verify that your onboard video or memory is not the issue.
Assuming you have tried the above, as to the screen flashing, it can probably be the LCD panel display. It can either be the video converter or your backlight inverter (or CCF fluorescent tube). Any of the two would require opening the display panel and component level repair. Should you not be comfortable cracking the display open and circuit analysis/diagnosis, you may need the services of a qualified professional.
Hope this give you an idea and work out for you. Good luck and post again how things turn up or if you need further information. Kind regards.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Acer TravelMate C312XCi Tablet PC
Email this problem
Email this problem
Can you Help with these Tablet PCs problems?
Repair Service
Find Tablet PC Repairman Near You:
