Related Tags:
This problem should be removed because:
Problem with Gateway Emachine Bestec ATX-250-12E PS 250w Replacement Power Supply Part Number P/N 100744 (PSATX25012E) Power Supply
Bestec atx-250-12z rev d hp model 5187-1098<br />pc will not start up when pushing button on front of machine green led on back of p/s flashes with power cord plugged in. does this indicate a p/s
failure?
Solutions (1)
Best Solution
I have already replaced mant Bestec ATX-250-12E power supplies because they have an internal failure. Consider yourself lucky if the thing doesn't power up your computer because it has a problem of imposing the +12 volt line onto the +5 Volt line then blowing out the mother board. Sometimes you aren't so lucky because once the damage is done then it is to late to just simply replace that piece of junk. I was lucky with my daughters E-Machine because if she tried pressing the start switch on the front of her computer it would sometimes come on and sometimes not. She just mentioned this to me and I immediately replaced that Bostec ATX-250-12E before it could do any damage to her computer. If anyone has an older E-Machine or an older Gateway machine then it would be a good idea to see if it uses that Bostec-ATX-250- 12E. If it does then go order another power supply, anything but a Bostec, and instead of a 250 watt order a 300 watt or better. I hope that this has helped those that might have this problem before it destroyes *********** boards. Marty
hp pavilion a375c will not powwr up
systen has a bestec p/s atx-250-12z- rev d green led light on back of p/s flashes when power cord is plugged in. could this be a p/s...
the pc wont power up and the green led on the PSU
the pc wont power up and the green led on the PSU is just flashing, is the bestec atx 250 12z broken?
Bestec ATX-250-12Z when power lead plugged into
Bestec ATX-250-12Z when power lead plugged into power supply the green power light gives a momentary flash and then nothing
power light on computer flashes..tried
power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer...
Add Your Solution
supply is dead please contact
supply is dead please contact cell no. 09950690202
in las vegas, where can i walk in and purchase
in las vegas, where can i walk in and purchase bestec ATX-250-12E PS 250w under $20.
My wife has an eMachines T1600 in her first grade
My wife has an eMachines T1600 in her first grade classroom. It worked in June when class ended, but does nothing now...
See all Gateway Emachine Bestec ATX-250-12E PS 250w Problems
Fix-O-Meter
2,186
2,186 people viewed this problem
- 1 person found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Gateway System Power Supply Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
