Question about Whirlpool 17 cu. ft. / 481 liter Upright Freezer EV170NLSS
Freezer's power is dead
Checked voltage drop across connections to back of fridge and have voltage. No internal light, or any sign of operation what so ever. Is there a module that controls freezers operation that could cause such a problem? Where should I start after confirming the source of the problem is not from outside the freezer?
I turned a switch in the back of self defroster receptacle and it turned back on. Just so happen that the light bulb in the freezer burned out at the same time the defroster timer failed to reset. I guess it was a power surge or something that could cause all that at once. Thanks Buffalo12980 saved me alot of money.
Posted on Aug 21, 2007
  • 625 Answers
Check the plug itself may be melted. next check the cord itself at terminations inside the freezer compressor section. if it's plugged into a gfci try resetting the gfci receptacle. check breaker, may have tripped off.
6ya staff
SOURCE:
Engel fridge trips power when mains power turned on. Fridge set in off position.
There is a dead short line to line or line to ground. The dead short can be detected with a electric continuity tester connected across the load side of the mains (power shut off) and opening covers and inspecting the wiring.
Aug 01, 2017 | Engel Freezers
I have a frigidaire fridge freezer. Its about 3 yrs old and has stopped working. I have done all the usual like checked the fuse. Before it stopped working had moved it across the kitchen..has moving it...
Hi!!
Did you plugg unit back to the wall outlet?? Is that outlet working??? Did the plug got damaged when disconnected?? Check unit's power cable for continuity. Check freezer temp. controls.
You can plug and unplug your unit as many times as you want an you should not have any problems.. Check the above mentioned items, I think it is where your problem resides.
Don't forget to rate this post!! Good Luck!!
Jul 04, 2010 | Freezers
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
I want to use my freezer for beer. Can I raise the temperature by changing the thermostat? Any other suggestions besides using a fridge?
Not sure of your make/model. If its a standalone freezer you could exchange the termostat with a Fridge, or you could jury rig a seperate line voltage thermostat with probe in the compartment, which you would plug the fridge into and would override the internal thermostat (internal thermostat would always be calling for cooling because the line voltage thermostat would be set higher--any time the temp increased above the set point on the line voltage tstat the relay would close and the freezer would run). An anti freeze alarm coupled to a simple relay or contactor would work for this purpose... depending on how handy you are I could explain all the necessary components...
Oct 11, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Freezer doesn't run
If you got power to the unit i would put a jumper wire in the thermostat ( unplugged the unit ,open the housing where the thermostat or cold control is ,and youll see two wires connecting to it ,put a jumper wire between both with electrical tape to insulated and plugg it in , if it works replace the thermostat with the same new one ) That's the most common problem when there's power and everythig else is dead.
Jul 01, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridge/freezer won't cool completely or freeze
Things to look for and fix yourself woulf be to clean the coils on the bottom and check the fan motor on bottom, make sure it is ok, Look on back of the freezer walls for frost buildup, a sign the defrost heater is dead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2009 | Freezers
Please help my indesit ta 5 fnf s is dead with no warning. no lights no power nothing. its not fuse power or socket
Had the same problem with my TA5FNFS once you have confirmed as there is power in the wall socket and the fuse in the plug and cable are ok, I found as the PCB control board had burnt out costs about £60 for a replacement board
Apr 30, 2009 | Freezers
Whirlpool 17 cu. ft. / 481 liter Upright Freezer EV170NLSS Logo
297 people viewed this question
Top Whirlpool Freezers Experts
Dennis Boxerman
jasbo
jasbo
Spencer Field
Spencer Field
Level 1 Expert
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
