have QX3+ driver for my intel play microscope but poses a directx8 problem with my vista computer..which directx8 driver will i download?!!!already have codex downloaded...pls help which directx 8.0 will i download
Step 3. Download and extract the QX3 Drivers from: http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
I have uninstalled QX3 download 3 times and reinstalled 4. Each time it comes up with a different...
(More)
I have uninstalled QX3 download 3 times and reinstalled 4. Each time it comes up with a different problem but the program will not run. The first time it said I was running the wrong OS. I was not. The second time it read, can not find microscope (light was on ). The third time it read Microscope is not turned on. Light was on and everything looked good. This is where I stand right now. How do I turn it on?
i have play Qx3 from my friend and i have windows vista and when i tray to make it work my pc say...
(More)
i have play Qx3 from my friend and i have windows vista and when i tray to make it work my pc say that it cant find all the necessary software components plz reinstall Qx3 software (85) so what can i do
i lost the cd with the down loads for the intel play qx3. and i got a different computer and i need...
(More)
i lost the cd with the down loads for the intel play qx3. and i got a different computer and i need to get the downloads again. how do i do this?
Can i use my qx3 as a barcode reader and if so where can i get the software neccessary to do so? Is...
(More)
Can i use my qx3 as a barcode reader and if so where can i get the software neccessary to do so? Is it possible to have it register into an excel spreadsheet?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
