Question about JVC AV-27530 27" TV
Blue screen nonworking tuner
I have the same blue screen and tuner problem described in the previous posting. This TV is 4months out of warranty. I went through the trouble shooting as described in the previous posting.I would like to replace the tuner myself. I have some electronic experience. If I could get the part and a schematic I believe I could do it myself. The TV only cost $200.00 so it is cost prohibitive to get a repair shop to do the repair. Estimate of $130.00 by local shop.
    Genius:
  • 1,153 Answers
Yes get number of side of tuner and call around. I use www.bluestar-online.com for some cheap parts. But there are others, MCM, Tritronics, Dalbani etc.
Posted on Sep 08, 2007
SOURCE:
My vx37l powers on get a blue screen then shuts down
Displays blue screen and shut down; denotes no signal input to TV. Check all the signal inputs, Ariel, AV or so. If all are found OK, the tuner to this TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 22, 2014 | Vizio VX37L Television
How do I fix the blue screen on my Akira tv?
Sounds like tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 09, 2014 | Televison & Video
MY TV SONY BRAVIA MODEL#KDL-40V5100 ONLY SHOWS A BLUE SCREEN AND IT DOES NOTHNIG
Sounds like tuner fault. Contact any service technician to check and confirm. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Hello out there, i have a 32 inch olevia lcd tv that got hit by a power surge\r\nand the tv screen with blue i still have sound help!
The main Tuner board is dead.That the board,where the incomming brocasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 09, 2010 | Syntax Olevia 327V 27 in. LCD Television
2005 sony 55'' sony wega. a very thin blue line is
Are you using a cable or sat box. If so then you are selecting channel using the tuner in the box and sending a constant signal to the TV eithir on one channel of the tv tuner or one of the other input of the tv. If this is the case I would suspect the box and not the tv because you say it is only on some channels.. If you are using the tuner in the tv with cable or antenna directly in I would say the main board that has the tuner on it needs replaced. Without a specific model number thats the best I can do. Hope this helps.
Nov 25, 2009 | Televison & Video
Can a flat screen TV with ASC tuner pushed inside be repaired?
sue_shellenb,
I am an installer for a nationwide big blue store. The inputs on the back of tv's are fairly fragile. In my opinion, if the tuner to tv interface is damaged, ("In the process the ASC tuner, or internal tuner, was pushed back into the TV and the technician said it couldn't be repaired.") it probably is not repairable. Or at least, not economically repairable. Cheaper to replace the whole tv.
On the up side, $850 is pretty cheap for a 47 inch flat screen.
Apr 05, 2009 | Protron PLTV-4250 42 in. LCD Television
Vizio LCD DTV 32 inch. Model L32. I can't 'scan' for digital channels. When I go to DTV, then Menu and scroll right or left to "TV tuner setup' I get a blue screen and nothing else. No key on the...
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Mar 23, 2009 | Vizio L32 32 in. LCD HDTV
Laptop doesn't recognize tv tuner anymore pt. 2
first off lets try pluggin in something else into that port to see if it will recognize that. if it does then we know it is not the laptop that is in question but the software or device mangaer properites.
Oct 01, 2008 | HP Expresscard TV Tuner For Windows Vista...
Sharp v29j200s always blue on the screen
Sharps are known for bad tuners and cold solder joints.If you tap on tuner and picture comes back there is cold joints in tuner, If not most likley bad tuner. if the audio is there with blue screen it is the tuner definitly.good luck
thanks DOCTOR VIDEO
Mar 25, 2008 | Orion1934 19" TV
Sony KP-41T15 Color problem
Does this happen when you play a dvd? if so your RED, GRENN, and BLUE lenses in the tv may be out of alingment. First try pulling the power on the tv (make sure the tv is turned off first) wait about 2 min. then plug it back in. If this stil continues, then what i said earlier may be the case and sorry to say unless you have a warranty you will be better off to buy a new tv. Now days it costs more to repair a tv than to buy a new one. And it could very well be the receiver
Oct 25, 2007 | Sony KP-41T65 41" Rear Projection...
JVC AV-27530 27" TV Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
