Question about Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive
I want to re set up my compaq presario 900
Every time i start up this message shows up, The image rpcrt4.dll is possibly corrupt. The header checksum does not match the computed checksum. Pls help me asap ... thanks
    Brigadier General:
  • 6,966 Answers
Hi, I checked my rpcrt4.dll, it is a 5692 kb, a check on the web says it is originally a 323.2 kb file Remote Procedure Call Runtime, v. 5.1.2600.1106 available for download at http://www.dll-files.com/dllindex/dll-files.shtml?rpcrt4 I believe it can also be extracted from the I386 folder of your XP installer CD. If your system will not boot fully, try F8 to boot in Safe Mode. Perhaps it may be worth your while to also do a full scan for viruses or ads/malicious software of your HD. Hope this work out for you. Post back how things are or should you need further information. Kind regards.
Posted on Aug 21, 2007
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Many DLL error messages on start up
Your Operating System is corrupted, probably by a virus or a program you recently installed.
The best solution would be to reinstall your Operating System (OS).
Remember to back up your data before OS installation.
Dec 29, 2009 | Microsoft Windows XP Home Edition
My laptop wont load to Windows XP when it tries to I get the following message. STOP:c0000221 {Bad Image Checksum} The image shell32.dll is possibly corrucpt. The header checksum does not match the...
your windows is surely corrupted.. install your windows again... if you dont know how to install your windows...contact me....at (bharat_s@ymail.com)
please vote for me...im sure this will solve your problem...
Sep 26, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Help
Greetings,
When you upgrade your computer to Windows XP, you may receive an error message that is similar to one of the following: C0000221 (Bad Image Checksum)
-or- STOP: C0000221 - Bad Image Checksum in ModuleName
-or- STOP: C0000221 - Bad Image Checksum. User32.dll is possibly corrupt. The header check sum does not match the computed check sum.
Please go through the below mentioned link:
http://support.microsoft.com/kb/326687
Sep 20, 2009 | Microsoft Windows XP Professional for PC
C0000139 Entry Point not Found computer will not boot-up.
Are you getting this error with RPCRT4.DLL. If you do you need to replace this file from the Xp disk.
If you cannot follow, send me a message at rocksmani@gmail.com and hope we can talk over gmail or skype and i'll guide you through.
It may be difficult for you to do it.But if you could do, here the steps are :--
1.Use the Windows XP Recovery Console to replace the RPCRT4.dll file with the original version. To do this, follow these steps:
Insert your Windows XP CD-ROM into the computer's CD-ROM drive or DVD-ROM drive, and then restart your computer from the CD-ROM.
Some computers may require that you modify the basic input/output system (BIOS) settings before you can start the computer from a CD-ROM. For information about how to modify BIOS, see your computer documentation.
At the Welcome to Setup screen, press R to start the Recovery Console.
Press the number key that corresponds to the installation that you want to repair, and then press ENTER.
Type the Administrator password, and then press ENTER.
With the Windows XP CD-ROM still in the CD-ROM drive or DVD-ROM drive, type the following commands, pressing ENTER after each command:
cd system32
ren RPCRT4.dll RPCRT4.old
CD-ROM_or_DVD-ROM_Drive_Letter:
cd \i386
expand RPCRT4.dl_ BootDriveLetter:\windows\system32
exit
It'll fix your problem. :-)
Mar 26, 2009 | Dell Dimension 4550 PC Desktop
I want to re set up my presario 900
Hi, I believe you posted twice. Here's the link *http://www.fixya.com/support/t185147-want_re_set_up_compaq_presario_900) to your other post with a possible solution. Cheers.
Aug 20, 2007 | Compaq Presario 900 /1500 Series EVO...
Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive Logo
71 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
