Concerning a Craftsman 24hp garden tractor. The right side pulley (r.side as you are facing the front of the mower)on the deck is loose and must be replaced. However, I cannot remove the 'nut' holding the pulley in place. Any suggestions.
Hello jejodaro:
>>You have to Hold the Shaft on the Blade Side with a Pipe or Strap Wrench or Depending on the Model, you can Block the Blade an Hold the Shaft so the Pulley Nut can be Loosened/Removed.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy. Thanks.
Respectfully
John
More info please. The deck, the engine etc.donnyb60
