Question about Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive
I want to re set up my presario 900
Every time i boot up or insert my set up recovery disk, this shows up... The image rpcrt4.dll is possibly corrupt. The header checksum does not match the computed checksum. Pls help me asap ... thanks
    Brigadier General:
  • 6,966 Answers
Hi, I believe you posted twice. Here's the link *http://www.fixya.com/support/t185147-want_re_set_up_compaq_presario_900) to your other post with a possible solution. Cheers.
Posted on Aug 21, 2007
SOURCE:
My hp laserjet 4100mfp didnot scan and email the document. it show error on display that no send opptions available. I already config the smtp default gatway.
It sounds like you need to reinstall the driver and application software and ensure that the unit is configured to scan and send. These are options when you do the initial installtion. This should give you application icons on the PC.
Sep 21, 2009 | HP LaserJet 4100mfp All-In-One Printer
Recovery CD not loading onto Hard Drive.
Your optical drive is not reading the disk properly - a common issue as time goes by. Replace drive with a good known working unit and your recovery operation will take place.
Mar 27, 2017 | Itronix GoBook XR-1 Tablet PC
C0000139 Entry Point not Found computer will not boot-up.
Are you getting this error with RPCRT4.DLL. If you do you need to replace this file from the Xp disk.
If you cannot follow, send me a message at rocksmani@gmail.com and hope we can talk over gmail or skype and i'll guide you through.
It may be difficult for you to do it.But if you could do, here the steps are :--
1.Use the Windows XP Recovery Console to replace the RPCRT4.dll file with the original version. To do this, follow these steps:
Insert your Windows XP CD-ROM into the computer's CD-ROM drive or DVD-ROM drive, and then restart your computer from the CD-ROM.
Some computers may require that you modify the basic input/output system (BIOS) settings before you can start the computer from a CD-ROM. For information about how to modify BIOS, see your computer documentation.
At the Welcome to Setup screen, press R to start the Recovery Console.
Press the number key that corresponds to the installation that you want to repair, and then press ENTER.
Type the Administrator password, and then press ENTER.
With the Windows XP CD-ROM still in the CD-ROM drive or DVD-ROM drive, type the following commands, pressing ENTER after each command:
cd system32
ren RPCRT4.dll RPCRT4.old
CD-ROM_or_DVD-ROM_Drive_Letter:
cd \i386
expand RPCRT4.dl_ BootDriveLetter:\windows\system32
exit
It'll fix your problem. :-)
Mar 26, 2009 | Dell Dimension 4550 PC Desktop
The monitor reads: system boot failure. Insert recovery disk.
McAffee Security or adding memory cards should not effect the ability to do a system recovery, but so be it. Here is a list of presario laptops, do you know which is yours?
s.gif s.gif s.gif » Compaq Presario 12XL325 Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ20-325TU Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ45-325TX Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ40-325AX Notebook PC
» Compaq Presario CQ40-325LA Notebook PC
» Compaq Presario CQ40-325TU Notebook PC
If so, click on it and you will find the recovery disks.
Mar 18, 2009 | Microsoft Compaq Presario C501nr Notebook
Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
At this point, you can try to clean your disk # 4 and see what happen,
or try to make a copy of disk # 4 (if you can copy the disk) and try again.
or
1) Contact your customer support and ask for a new set of disks.(or only # 4)
or
2) Boot your computer with another OS disk (win XP)
or
3) Boot your computer with some utility disk
Oct 19, 2008 | Gateway MX6421 Notebook
Compaq Presario Disk Boot Failure, insert sytem disk and press enter
If you have your original Windows install disk, you can boot off of that, and should be able to recover most of your files, assuming your drive has not died fully. Depending on how important your files are, you can send the drive to a drive recovery service. I did that a couple years ago, they were able to recover all my files but it was EXPENSIVE. $1200.
Feb 19, 2018 | Computers & Internet
When I try to boot up my Compaq Presario model no SR 1420UK, I get the message: “Windows could not start because the following file is missing or corrupt: <Windows...
You can download the hal.dll file from this site www.dll-files.com/dllindex/dll-files.shtml?hal most of the windows missing dll files you can find here.
Also download windows nt or xp boot image from the net and create floppies or cd rom from that to boot up.
IF YOUR HARD DISK IS AN FAT32 PARTITION ITS VERY EASY AND YOU CAN USE WIN98 BOOTDISK WHIHC IS SINGLE DISK AND CAN ACCESS THE WINDOWS SYSTEM FOLDER AND COPY THIS HALL.DLL FILE.
AFTER GETTING PROMPT GO TO
C:\WINDOWS\SYSTEM32
COPY THE HALL.DLL
problem solved
Jul 20, 2008 | Computers & Internet
I want to re set up my compaq presario 900
Hi, I checked my rpcrt4.dll, it is a 5692 kb, a check on the web says it is originally a 323.2 kb file Remote Procedure Call Runtime, v. 5.1.2600.1106 available for download at http://www.dll-files.com/dllindex/dll-files.shtml?rpcrt4 I believe it can also be extracted from the I386 folder of your XP installer CD. If your system will not boot fully, try F8 to boot in Safe Mode. Perhaps it may be worth your while to also do a full scan for viruses or ads/malicious software of your HD. Hope this work out for you. Post back how things are or should you need further information. Kind regards.
Aug 20, 2007 | Compaq Presario 900 /1500 Series EVO...
Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
