Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain
The washers has a load in it. It won't drain. Lights are on. We unplugged it. It acted as though it would re-start, but didn't. Not sure what to do to re-set it Richard
    Novelist:
    Champion:
  • 244 Answers
Right take your drain hose from under the sink and place into a bucket low to the ground if water starts to drain out then do this until nothing else comes out the door will open after a short time in which you can get your clothes out if it doesnt than you will need to take the washer outside and disconnect the drain hose from your pump you need to take it out because once you full off the hose from the pump you will not be able to stop the flow of water and there will be alot if water comes out then your pump is faulty
Posted on Aug 22, 2007
Maytag washer starts drain pump and nothing else works
best guess timer issue
timer runs all the water ins and outs and wash cycles
or depending on model electronic controller board
not sure why the machine is unplugged often
it is worth buying a one plug surge protector
hint
unplugging to fix any washing machine during a set wash cycle only interrupts the timer
spinning the timer around fast to restart an unfinishied cycle .damages the timer
Oct 11, 2016 | Maytag Washing Machines
Duet Washer Won't Start; Outlet Fine
How old are they & where did you get them from?
Jan 30, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer mav4757aww was agitating a little then would stop and make a slight humming sound. Now it won't agitate at all , it just hums and starts to smell like something is getting hot. It will...
Unplug the unit and remove the front panel and look at the space between the motor and transmission find the coupler that connects the two together this could be broken. You may have to lay the unit on it's back to check this out. It's a cheap fix if its the coupler. Let me know.
Sep 27, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washer is Full of water and clothes but won't drain. The washer will not start in any cycle. Lights are on ( the start light is blinking). Tried unplugging but still will not start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washer will not unlock
Try unplugging the washer for 30 seconds then run a rinse and spin cycle. If it is still acting up you can remove the top panel and reach your arm down the front right side and find the door latch assembly. At the bottom up it is a pull tab. Pull that down and you will release the door latch. Image Whirlpool WP8182634 Door Lock Latch PartSelect
Feb 22, 2018 | Maytag MAH6700A Neptune High Efficiency...
Tromm won,t drain
Peace,
ngafm at your service!
Lets try this first!
Unplug the washer for 5 minutes and then replug and try it to see if this reboots the system like when a computer acts up, we do the same thing for most electronic devices!
If for some reason this is not helpful, open the user guide and see what they tell you for this specific machine!
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 04, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Frigidaire Washer won't drain water
My will start to cycle and then it will cease to spin. No grinding, no off balance noise-no spinning=no draining of water from tub/basin. Unplugged it for a full 4 minutes. Plugged it back in. Checked to see if washer was level-it wasn't. Made adjustments to ensure washer was level-EUREKA! washer finished cycle no problem. BOO-HISS! Two loads later, same issue as the first time-washer won't spin. Checked to see if washer was still level-it is, new issue-error coed E20 and all lights blinking. ANY suggestions?
Jun 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
48 people viewed this question
Sal De
Marvin
Marvin
jimorris77
