Question about Frigidaire 18.4 cu. ft. Top Freezer Refrigerator with Ultra Soft Door Handles
Galaxy Refrigerator i need help on install a refrigerator handle
  • jbrownsugar Aug 22, 2007
    the model number is 25363802202. i have the handle. the handle came with a white plastic block&screw. I
  • jbrownsugar Aug 25, 2007
    I fixed the problem
  • 291 Answers
Need a model # and what kind of help?
Posted on Aug 21, 2007
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
How do I replace the refrigerator door handle?
loosen the allen head set screws located close to each end of the handle.. loosen but don't remove all the way.... install the new handle tighting the set screws snug but not too tight, u don't want to strip the screw head........... hope this helped............ ken
Sep 30, 2014 | Amana BC21V1W Bottom Freezer Refrigerator
Tighten door handle on Whirlpool Conquest refrigerator
You need to remove the handle befor eyou can tighten the mounting bolt behind it. T remove the handle just grab it and yank UP quick and hard. The handle will unclip and release, then you can tighten the bolt down and re-install the handle.
How strong do you have to be?!!! Trying that and it won\'t unclip. Not sure how hard to try--or will you break something?!!
You have to pull up pretty darn hard with a jerk. That is how both handles are removed on these conquest refrigerators
Sep 01, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Galaxy refrigerator
HI.TONY.try defrosting all first.it might work.normally if freezer ices up your fridge would stop working.in this case is the opposite.is the freezer ok?realistically it needs a visual check .fridge to freeze up it sounds like the thermostat .flaps sensor or board.hope this helps ali
Jul 12, 2012 | GALAXY Microsystems 25.4 cu. ft....
Water leaking
I think this will help..
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Aug 21, 2008 | GALAXY Microsystems 25.4 cu. ft....
Galaxy 25.4 Color change needed
check out www.applianceart.com, they have black magnetic and vinyl covers that cover your fridge. They even have stainless steel options.
Apr 07, 2008 | GALAXY Microsystems 25.4 cu. ft....
Warm Refrigerator
if the freezer is ok it may need a full defrost. try that in the first instance then re use- if the same problem occurs it may be the stat.
Jun 14, 2007 | GALAXY Microsystems 63702 Top Freezer...
Refrigerators Logo
74 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
