Question about HP Photosmart M425 Digital Camera
Hp Photosmart M407
Camera won't stay on - have tried various freshly charged batteries. The green light comes on for a few seconds, then goes back off. Sometimes the logo welcome screen appears briefly but then goes right back off.
  • firepper red May 11, 2010
    I have the same problem... it started after someone dropped the camera. I will try and take it apart and see if I can find something that may be loose... I will post again if I can figure it out
You are stupid
Posted on Oct 07, 2008
I need a charger for M407 HP camera.Where can I get one?
The M407 uses standard AA batteries, rechargeable or disposable. If you want to use rechargeables, you should be able to buy a suitable charger at just about any department, electronics, or office-supply store.
The camera won't charge the batteries, and never try to charge disposable batteries in a charger.
Aug 05, 2011 | HP Cameras
Turn on cameron switch, power comes on then goes off
are the batterys replaceable , i hope so , sounds like
they arent holding a charge .
If it takes AA s try a pair of akaline .
Aug 13, 2010 | HP Photosmart M407 Digital Camera
Battery won't charge on my HP photosmart M407. Batteries are new. What else might be wrong?
It could be something wrong with the power board. If you have an external charger to charge the batteries. After fully charged tried to take as many pictures as you can. If the battery discharge fast, that mean something is wrong with the power board.
May 19, 2010 | HP Photosmart M407 Digital Camera
The camera's battery died yesterday. I changed the batteries this morning and now I only get the green light to come on, but the light stays on when the camera is off as well
It sounds like your power on button may be stuck, if the ON indicator is always on. That may be the reason your battery was dead yesterday. Try reinstalling your batteries, checking carefully the positive and negative positions, and working your power button several times rapidly to see if it is stuck. If it is still showing a constant ON condition, try the following steps. With the batteries out of the camera, try a tiny bit of rubbing alcohol around the power switch, working the switch rapidly for a few seconds to see if that frees it. Replace the batteries with known fresh ones and try to power up the camera. That may fix your problem. If not, the camera will probably have to be repaired or replaced.
Mar 22, 2010 | HP Photosmart E327 Digital Camera
Camera won't turn on
I am assuming that the power does not go on or it immediately turns off as it is turned on.
Try the docking station or the 3.3 AC adapter to the camera. Plug that in to live power. If you hear the lens motor (by default the lens is retracted to closed position when plugged to AC power), then the camera is operational. If not, there is power failure with the camera.
If the lens motor work, then try to turn the camera while plugged to AC power. If it turns on, then there is something wrong with the battery or with the chamber. If the camera does not turn on, then check the button board for a bad power switch.
Check the LCD closely under a bright light when you do this test. You may see a faint a flash of display that disappears. I have not figured out what causes this. This would mean that camera power supply is working but nothing is telling for the camera to stay on.
Aug 02, 2008 | HP Photosmart M407 Digital Camera
Hi, can you help me with this?
is it a brand new camera? how long have you had the camera? are u puttin the batteries in the correct way? maybe u can try different batteries for now see wat happens if not write me back.
Hope this helps!!!
Apr 19, 2008 | HP Photosmart M407 Digital Camera
CAMERA IS NOT FLASHING
The camera is recharging the flash. (possible cause)
Solution: It takes longer to charge the flash when the battery is low. If you see this message alot, you may need to replace or recharge the battery. Hope this helps!
Nov 27, 2007 | HP Photosmart M407 Digital Camera
HP Photosmart M425 Digital Camera Logo
124 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
teddyboy
Are you a HP Camera Expert? Answer questions, earn points and help others
