HI I have a Maytag MAH2400AWW front load washer and when it spins it is very loud and i noticed that the Tub is leaning down slightly to the right and slightly downward Looks wobbly when its spinning
Is there anything that is stabalising the tub that i should look at
Dear Hi, The reason for the nuisance is that the vibration mount on front end of the tub is worn out and you need to replace the same. you can DIY but its better if you take a technical help with someone who knows how to change them. Replacing the vibration mounts will solve your problem. Make sure that you replace both the mounts as otherwise it may again lead to unbalanced mounting and you may have the problem again too soon on the otherside.
