Question about Pacific Image PrimeFilm 3600 PRO Film Scanner
Installing scanner drivers
Just bought a new PC which has windows vista which wont reconise my PrimeFilm PF 3600Pro scanner drivers when I try to install them from the software disc. Eny solusions? Toni.
  • 3 more comments
  • rogart Aug 23, 2007
    sorry folks Iam afraid the drivers would not talk to the scanner. One off my friends found a site that said the scanner (unfortunatly that pasific model is not compatable with vista,but I will keep trying sorry for not getting back with the result.
  • old slides Apr 19, 2008
    How do I get my new PC w/Vista Home Edition to work my Prime Film 3600 Film Scanner?
    Neal
  • Crowsnest Apr 28, 2008
    Purchased one of these off EBay. Came without software disk but I down loaded it from oem site www.scanace.com. This software will not properly install the drivers on my system. Scanner appears to be in good condition and is recognized by XP when plugged in and switched on. If I run the software installer it runs and reports the drivers successfully installed, but device manager reports no drivers installed on on the scanner entry. Found something called 'update.exe' which was supposed to fix this but it makes no difference. Scanner software unsurprisingly then fails to initialize scanner. Any ideas?
  • Anonymous Jun 05, 2008
    I have a PF3600 PRO that I used for several years without problems. I am installing it on another machine XP Pro SP3 using the latest driver from the manufacturer's driver site. I also found the UPDATE file. Windows will not recognize the driver.
  • Anonymous Oct 15, 2008
    need a driver for vista as well!
I have the same problem of Crowsnest
Posted on May 01, 2008
    President:
  • 1,114 Answers
You can download the software from the link below: http://www.scanace.com/download/drv_pf3600.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 20, 2007
SOURCE:
I have a primefilm 2700 scanner and I'm looking for drivers for this scanner for windows 7, can you help out?
Scanners are often not supported when a new operating system comes along.
The simplest solution would be to run an old computer with the correct drivers for the scanner, I'm afraid. You can probably get an old computer for around £30.00, which is far cheaper than buying a new film scanner.
Jan 20, 2015 | Office Equipment & Supplies
Pacific Image PrimeFilm 1800u Film Scanner : is there a Windows 8 driver out there somewhere? Can anyone offer some help in finding it?
PrimeFilm 1800u will not work on Windows 8.
Here is the response I received from the company for the question:
Where can I get drivers for windows 8? Windows 7 drivers are not working on Windows 8.
Response:
Hello, This scanner will not be supported on windows 8, all of our USB 1.0 technology scanner will no longer be supported beyond Windows 7.
Wendy
Dec 19, 2012 | Pacific Image PrimeFilm 1800u Film Scanner...
Trying to download a driver for primefilm 1800u
The drivers it needs are in Windows\system32\drivers and include usbscan.sys and 2 others. I discovered that I had to run the device troubleshooter until it came across the single image scanner, I let it install drivers and then it worked with the primefilm software. That took hours, but the solution was to let Windows 7 64 bit do a troubleshoot on the hardware.
Dec 26, 2011 | Pacific Image PrimeFilm 1800u Film Scanner...
Trying to use PrimeFilm 1800U scanner on my Dell PC (with Vista), but when running supplied Presto ImageFolio (Mr. Photo) CD, the following message appears: 'String MSG_OS was not found in string table'....
Uninstall Presto Mr Photo, image folio & Cyberview, all of which are not Vista compatible. Obtain new scanner drivers from http://www.scanace.com/en/download.php. Also, can use any image editor once scanning complete. Google provide free application called Picasa at www.picasa.google.com.
Sep 09, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
Instruction manual for Prime Film 1800U scanner
yes the driver can work on Vista systems, you can find manuals and drivers here:
http://www.scanace.com/download/Cyb_X_SF.htm
cheers
Jul 24, 2009 | Pacific Digital PrimeFilm 1800u Film...
Computer can't communicate with scanner.
Go to START menu click on devices and printer, then locate and click on add device, and follow the instructions.
Hope this helps you
Mar 08, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
LEXMARK 8300 ALL-IN-ONE PRINTER
Hi Duff
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Dec 14, 2008 | Microsoft Windows Vista Ultimate Edition
Pacific Image PrimeFilm 3600 PRO Film Scanner Logo
1,105 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Ekse
Alun Cox
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
