Question about Whirlpool GI1500XH Stainless Steel
Ice maker GI1500XHW
The ice mager stop making ice, but I saw the froster on the pipe inside of the bin. I noticed that the exhaust fan for the compressor is not spinning, not sure if it is the issue.
  • mark_ling Aug 27, 2007
    OK, Now the fan is working, but it is still not making ice. It only has frost on the copper pipe inside of the bin. Except for not making ice, everything is good, the water is flowing and draining periodicaly, any suggestion ?
  • mark_ling Aug 29, 2007
    Thanks for the response. I checked the evaporator plate, it does not get frost after the water pumb is runing. The only frost I can get is from the copper pipe underneath the plate, and only part of the pipes is very cold with some ice and frost wrapped around it. Not sure what is the issue. This ice maker has been runnig ok for 4 years, never had any issue.
    President:
  • 331 Answers
You have frost on the pipe, that's good. It means the compressor and its charge of Freon is still OK. You didn't mention whether you had water flowing or not... I'll presume so. The fan by the compressor is crucial. It must be running in order for this unit to make ice. OK, you have removed the 4 screws holding the lower panel and removed the panel. The entire unit must be removed from the cabinet to proceed. Pull it out. *Take note of the drain hose, this may be difficult to re-install. After you have it out, unplug it, turn the water valve off and remove the cover off the back of the unit. Now reach in there with your hand and feel the blades on the fan, rotate them... do they rotate freely? If so, your condenser fan motor has failed and must be replaced. Getting to it... Go to the front of the unit, remove the two bolts holding the cabinet to the base. Then tilt the cabinet backwards, this will expose the problem child. (be careful not to bend/kink any copper tubing or wiring when you do this. And prop the cabinet so that it doesn't fall back down or fall all the way back.) Now, replace the fan motor with part #4387244, it can be purchased for about $70 at you local appliance parts store. Rebuild and you are good to go!
Posted on Aug 21, 2007
  • Tracy Farrell
    Tracy Farrell Aug 27, 2007
    Here's how we test these...Completely remove the cutter grid, pull the plug on the water tank and let it drain so it runs empty.
    Now, in "production" mode (water pump running) the evaporator plate (where the ice sheet forms) should begin to frost over fairly quickly beginning from the outside and working inward. This is good. There is a thermister (a temperature sensing device that communicates with the on board computer) beneath the evaporator, it will chill rapidly. When it reaches ~-2 degrees, the computer will initiate a "harvest". The time for the thermister to reach -2 is between 4 and 5 minutes.
    If your computer never goes into harvest, and the evaporator plate is completely frosted over, you have a bad evaporator thermister. This is an easy repair, unplug the rear wire connector by the cutter grid on the right hand side. This is the thermister connector, by disconnecting it you set the computer to its' "default" harvest of every 20 minutes, period... regardless of the thermister problem.
SOURCE:
Makes ice but water want stop running n to ice bin
If you look above / behind your ice bin you'll notice a plastic hose wich feeds water to your ice maker. It may be loose or cracked allowing water to drip to your ice bin.
Oct 17, 2016 | Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38...
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 12, 2012 | Refrigerators
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Stopped making ice
Usually, the water line to the ice-maker is frozen. If you defrost the freezer, it should work again.
Aug 22, 2009 | Refrigerators
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
Feb 13, 2008 | Refrigerators
Whirlpool GI1500XH Stainless Steel Logo
120 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
