Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Philips 60" projection screen
TV quit and only get flashing red LED when you press power button, this is the second time this has happened, first time was under warranty so they replaced entire board to ensure me I would have no future problems, now this piece of $%#@ TV has died again, $2000 flushed down the toilet
  • Anonymous Mar 21, 2008
    i have the same problem with the led just turning on and not the tv
    Problem Solver:
  • 5 Answers
It may have a bad blue crt they are know to cause trouble arcing and when they do they damage the LSB board you can buy the board yourslf but if the tube is doing you in it must be replaced too,
Posted on Jan 24, 2008
SOURCE:
The TV keeps going into standby mode , comes back to proper picture and with-in 15-20 seconds goes back into standby mode. It happens continueously.
May I know if the standby led light at the front panel is blinking, if so please count how many times it will flash to determine the error code? If not follow the steps below.
In standby mode press the button of the remote control in sequence, " Display ", " Channel 5 ", " Vol (-) ", " Power ". Self diagnosis screen will displays. Le me know the result.
Jdvillanueva
Sep 02, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Tv won't turn on.
  • Try resetting the lamp timer
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
May 06, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Philips 60" HDTV Rear Proj NO POWER
Is the led flashing or just steady light? Also do you hear a click when you hit the power button?
Apr 07, 2008 | Philips 60PP9202 60" Rear Projection...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
