Question about LG VX3100
Charge complete but phone/display does not work
The display indicates that the phone is fully charged when I plug in the charger, but when I unplug the charger, the display screen does not even light up. Unable to use phone even when the charger is plugged in. I have removed, wiped off and reinserted the battery. And no, I did not drop the phone in the bathtub. Any suggestions as to what the problem might be? New battery? The phone is only about 6 months old. Thanks for your help!
  • 27 Answers
It is technical problem pleas go to sarvice center and replace u r handset cause it is in warrenty dont try to open it, or change with new battery
Posted on Aug 20, 2007
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
Iphone wont charge
The battery might be damaged, but in most cases you can just let it be plugged in like you normally do. It doesn't show "recharging" because it has been too drained.
Turn on your phone after 15 min. in the charger.
If it still doesn't work, then you have to ask a store that supports Iphones.
Aug 06, 2014 | Apple iPhone 4S
Help me with a merit 4.2 no book,
Turn chair and lights off when charging. The charger and chair will indicate with lights when charge is complete. All lights in full green and display showing full means you are done charging.
Aug 17, 2012 | Health & Beauty
Serius error do not charge, do not use the phone
Are you using a replacement charger or one that is not original? If yes, it's normal to have that error when charging. Remove it then plug it again so you can continue charging. It happened to me when I got a replacement charger and even though it gives me the error, I just unplug it then plug again until the phone is fully charged.
My nokia 5610 have no power at all but when i start to charge it has the indication of charging
This is because the only power the phone is receiving is from the power cord from the wall. When this problem occurs, it is because the battery in your phone is completely dead and not capable of receiving a charge (in other words the battery is fried). the solution would be a new battery. A tip on avoiding this problem in the future would be to only charge the phone to a "full charge" and then remove the charger. Avoid leaving it on charge all night while you sleep as this is the main cause of battery death. Also car chargers are another culprit, which is an un-known fact. a car charger uses a different kind of electricity which is stronger. If you have ever noticed that if it takes an hour to fully charge your phone when it is plugged into the wall, it may only take approximately 20 minutes to fully charge the phone in your car. So you if you must charge your phone in your car, charge it for no longer that 10 to 15 minutes at any one-time. good luck
Jan 20, 2011 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
My battery on my samsung g600 keeps going flat, when charging after a minute it displays battery fully charged. when charger is unplugged it is flat. bought new battery which just wouldnt charge. is it...
send the phone away for a warranty repair thats if its still in the 12 months warranty. sounds like the phone. since your phone is working with the charger in it, that points to the battery but if you bought a new one then it has to be the phone unless you are very unlucky in getting 2 dysfunctional batteries. But the best way around this is to send it away under warranty
Oct 21, 2009 | Samsung SGH-G600 Cellular Phone
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Battery indicator light blinks red
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
Apr 28, 2007 | Motorola Mobility RAZR V3
LG VX3100 Logo
106 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
