Question about Frigidaire 18.4 cu. ft. Top Freezer Refrigerator with Ultra Soft Door Handles
Galazy Refrigerator I need help on putting on a door handle
  • 291 Answers
Need Model #
Posted on Aug 21, 2007
SOURCE:
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
How to tighten handle
RobLey,
What brand of refrigerator? If you put it in, it did not come through with your question. Also, what type of refrigerator do you have? If you have something like a French door or side by side, sometimes they have a set screw near the top or bottom of the handle and that can come loose and needs to be tightened. Hope this helps!
Aug 06, 2015 | Refrigerators
How do i remove the fridgerator door handle
HOW TO REMOVE DOOR HANDLES (LFX25960
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
1. Removing Refrigerator Handle
Grasp the handle tightly with both hands and slide the handle up (this may require some force).
The keyhole slots on the back of the handle allow the handle to separate from the mounting screws.
CAUTION:The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION:When you assemble or disassemble handle, you must push or pull with reasonable force.
2. Removing Freezer Drawer Handle
Press the handle against door first.
Grasp the handle tightly with both hands and slide the handle to right (this may require some force).
If you need help:
http://us.lge.com/download/product/file/1000003873/LFX25960_LFX21960owners.pdf
Apr 29, 2011 | LG LFX25960ST Stainless Steel French Door...
Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Door Handle Issue
I may need the entire model # off the sticker inside the fridge section to help.  Most side by sides have a slot that the handle fits into and just pull down hard to lock into place.  May need to take the handle all the way off and tighten the screws on the handle and on the door first.
Oct 27, 2007 | Kenmore 55603 Side by Side Refrigerator
Replace door
The fridge should have come with a card that looks like a credit card to remove the handles.  There are directions in the manual on how to do this.  If you don't have the card then use a sturdy card like a drivers license.
Oct 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
