Question about Logitech X-530 Computer Speakers
Speaker hook up
I had my friend install a new soundcard for a 5 channel logitech surround sound system , and he plugged them all in to the three outlets in the back, then i moved and forgot the pattern , and i can only get 4 out of 5 speakers in all combinations, the sound card has 4 jacks : green yellow pink and then blue, and my logitech has only three black green and orange , can you help me?
    Sergeant:
  • 457 Answers
Methinks he joined an extra to one of the fittings you will need to do the same. When you join up the four let one hitch a ride so to speak on one of the connections.
Posted on Sep 04, 2007
SOURCE:
HOW TO HOOK UP ALL MY X-530 LOGITECH SPEAKER ON MY PC
You'll only be able to get true surround sound utilizing all the speakers if you have a sound card with multiple outputs (usually color coded as Green, Black, and Orange). Plug the satellite speakers into the subwoofer and run the three input wires (Green, Black, Orange) to your multi-source output.
If you only have one output on your PC (common), you should just connect the green wire and press the "matrix" button on the system. This will just duplicate the sound output into the other channels but is not "real" surround sound.
Hope that helps.
Feb 07, 2010 | Logitech X-530 5.1 Channel Speaker System...
[logitech 5.1 x-540] my front speakers arent working but i have 5.1 channel sound card
Go through systematically and check all connections. Start at your PC. Is the soundcard set-up correctly? Is it set to 5.1, stereo? Next, look at the wires. Are each of the wires plugged into the correct places? (you may need to refer to an instruction manual for this) At the other end of the wire, are they plugged into the right places on the back of the subwoofer? Are the front satellites plugged into the right places? After this, are the speakers themselves functional?
Usually, I find it's a connection along the way, nothing more serious.
You may have a more serious problem, in which case it would be difficult to fix, but for now, there's a simple check for you.
Jan 11, 2010 | Logitech X-540 Multimedia Surround Sound...
Having trouble hooking up logitech surround sound system
Hi , just make sure that your PC has a 5.1 Channel Sound Card that can handle that Surround sound system
Thanks
Dec 28, 2009 | Logitech G51 5.1 Multimedia Surround Sound...
I hear music on stereo not 5.1 im with x-530 wtf is the problem??!?!?
HI , this means that your soundcard is not 5.1 Channel , and the speakers are , and 5.1 = Surround Sound , without a 5.1 Channel Sound card you will only be able to obtain Stereo out of it...
Sound cards are cheap these days , look for one and it will work perfectly.
Dec 26, 2009 | Logitech X-530 Computer Speakers
Only 2 speakers work even though its all plugged in correctly. Ive hooked it up to an i pod
Hi , Just to clarify is your Sound Card that you are connecting it too , a 5.1 Channel Sound Card?? if not then that is the problem as it is a 5.1 Surround Sound System..Reason for it only coming out of 2 speakers when you connect it too an ipod , is the Green Cable Doesnt Comply with all the Speakers , you need a 5.1 CHannel Sound Card to connect all the Cables into.A 5.1 Channel Sound Card looks like this http://www.dclstore.co.uk/images/products/genius-soundmaker-value-5.1-channel-sound-card-16-bit-pci-31720009100-l.JPG
I hope this helped bud ,
Have a Happy new Year :)
I have a x-540 speaker system I brought today. Do I need a sound card to make it work with my pc. I hook it up/no sound.
A stereo computer system with resources to produce and record surround sound channels. Such surround sound channels are played or recorded using an audio card added to the computer system, which audio card controls additional speakers and/or microphones. Software for redirecting instructions from existing stereo application programs and sending these instructions to the existing audio device driver and the additional audio device driver is needed. Resources for processing the digital audio data for either extracting surround sound channels from two channel data provided by the application, or for encoding two sets of two channel audio data recorded by the two audio cards is also needed
Dec 02, 2008 | Logitech X-540 Multimedia Surround Sound...
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
X-530 rear and mid speakers not working
Hi guys.
Right, I am not technically minded at all, and all this talk about updating software and plug-ins baffled me. I bought my Logitech speakers 3 days ago, and happily plugged them into the soundcard, only to be puzzled that only my front speakers and subwoofer worked when I played music or video. I then had a brainwave. Using the 3 in 1 port that logitech provided me with, I got myself a phono to mono lead, which you can get at all good electrical stores, (take the three way box with you if you are stuck) Then proceed to plug the three speaker outputs into the box, colour co ordinated, then the phono end of the phono to mono lead in the box at the other side. Then using the single input, plug it into the input of your Soundcard. My soundcard has 8 inputs, so I just kept trying them all until sound came out through my speakers. A much less technical answer than changing all your drivers, creating profiles, fiddling with the deep insides of your PC. Hope this is of some use to you guys!
Jim
Nov 14, 2007 | Logitech X-530 Computer Speakers
3 of 5 speakers not working.
Go into your computer audio system and make sure you are on you are not set on stereo
Oct 20, 2007 | Logitech X-530 Computer Speakers
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Logitech X-530 Computer Speakers Logo
161 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
