Question about Samsung SP-R4232 42 in. Plasma HDTV
Audio but no video
TV is aprox. 1 1/2 yrs old. Working fine then the picture went black but the sound was fine. Trying checking power cord, cable card and cable into tv. Nothing else hooked to tv. Menu does not come up, no images or colors on screen at all. Any suggestions?
Just had replaced 2 boards for the same issue with authorized repair samsung dealer. be ready with $550 approx!!!!
Posted on Jun 12, 2008
    Genius:
  • Samsung Master
  • 1,689 Answers
If the screen is not illuminated this can be from the screen power supply, the main screen driver board, or the screen itself has failed. The service rep will change boards to service this, and adjust as necessary.
The set will require factory level service.
Jerry G.
Posted on Apr 18, 2008
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Lg LCD tv less than 2 yrs old has sound but no picture. What could be the problem? power supply, main board, etc??
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 18, 2016 | LG Televison & Video
Bought sony bravia 6 37" lcd hd tv 2 yrs ago +$1,500 when picture went dark, then out; srvc repair diagntc $75+tx. Now, we hv audio but only one channel wh cannot be seen & remot doesn't work. Were...
1,If you still have the old tv, reconnect.
2 turn on power after connecting cables making sure audio goes into ado and video into video.- very important.
3. do you get the pic, and sound?
4 if you do, do the settings to your choice.
will talk about new if the old does not work, good luck lindamilo.
Dec 25, 2013 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Loss of picture
Inverter board has failed. You can get replacement inverter by contacting the people over at www.tvcircuitboards.com
Jan 01, 2013 | Televison & Video
Emerson CR202EM9. The video on video 1 and 2 are not working. I am trying to connect my xbox, and the sound works on both video channels but the screen is black. whats wrong? the yellow video cable is...
Try wiggling it the video cable. I have a TV with a messed up video plug-in from pulling cords off it, and when we wiggle it then the screen will flicker the image and we keep wiggling it till the picture stays on the TV screen.
Nov 02, 2010 | Emerson CR202EM9 TV
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
NO PICTURE OR NO SOUND it just black
power supply not working -- did you check internal fuses on board --? if everything checks alright - replace the power supply board
Mar 02, 2009 | Televison & Video
Vizio P42HDTV sound but no picture just a black screen
SOLUTION: I have a P42HDTV10A that i purchased in 8/06. It went out for the 1st time 9/08, then again on 3/09, then again on 5/09. The same issue, audio but no pic. I appears that this has to do with either the "Y" and "Z" boards. 1st & 2nd times Y board was replaced, then 3rd time the "Z" board. I have now found out that you need to replace both at once because one is the reason why the other gives out and no one can tell why it happened. Parts can be ordered from www.encompassparts.com . I found a 113 pg vizio repair manual that i can send you in case you are interested at trying this. By the way, i purchased ext.warranty for 5 yrs so it has costed me 0...but for those that do not have the warranty and are mechanically inclined give it a shot. It will cost about $400 to buy both
Feb 11, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
RCA Projection TV
that would be the inverter board, supplies power to the bulb, you would need to replace this part, but don't touch the board without wearing rubber gloves, as it can store a lot of voltage when they fail . when you get the board out discharge the capacitors to make it safe. cross the live and negative on the capacitors.
Jul 08, 2017 | RCA Televison & Video
Samsung SP-R4232 42 in. Plasma HDTV Logo
237 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
