Question about Sylvania DVL-515 DVD Player
A dvd will not stay in the player
Every time I put a disc in the player it just ejects right back out? I've tried several discs and it doesn't like any of them
  • 625 Answers
Inside the unit, when the carrier slides back in there is an infrared led and photo transister that detect the presence of a disk. it may be adjusted too far away from the carrier so its as if there isn't a disk inside. sometimes the four springs that hold the disk carriage are weak and the carrier is tilted away from the sensor. try looking at these springs.
Posted on Aug 21, 2007
SOURCE: sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Posted on Jan 18, 2007
SOURCE: Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Posted on Jan 28, 2007
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
SOURCE: It keeps ejecting the disc and saying disc error
1. Power up unit with no disk in the tray
2. After "no disc" shows on the front display, press PAUSE on the remote
3. Press in order: 1, 4, 7, 2 on the remote (short keypresses). A new screen will show up, EEPROM settings with a green background
4. Write down the EEPROM string for backup/restore purposes in case you screw up. My string was 55 53 00 45 02 55 64 FF (compare with the default string of the 312, which is 55 53 00 45 14 55 64 FF).
5. To enable VCD playback, move the cursor to the "45" (4th group of characters from the left; use the remote up/down arrows to move right/left) and enter "46" or "47" instead, then press ENTER to commit
6. To enable SVCD playback, move the cursor to the "64" field (second from the right) and enter "FE" instead. To enter "F" press "6" on the remote and keep pressed. To enter "E" press "5" on the remote and keep pressed. After you're finished entering "FE" press ENTER on the remote to commit
7. Press PAUSE on the remote to exit the EEPROM screen
8. Power off, then power on again the player
9. It now plays SVCDs and/or VCDs depending on the codes you entered.
The final EEPROM strings with both VCD and SVCD enabled are:
55 53 00 46 02 55 FE FF and
55 53 00 47 02 55 FE FF
(either works)
NB the replacement of 64 by FE was in the past wrongly labeled as Macrovision hack. That's not true. What it really does is enable SVCD playback. If you only do the #5 above, you'll only get VCD playback. If you only do the #6 above, you'll only get SVCD playback. If you do both, you'll get VCD and SVCD playback.
(SVCD playback was especially important to me because I have several hundreds of them - mostly TV shows recorded on my TiVo, then exported to the PC and converted to SVCD)
The other hack for the DVB-312 also works on the 412 (see the configuration screen):
1. press SETUP on the remote
2. Go to "TV Aspect" and move the cursor to "16:9"
3. Press in order: 1, 3, 9, 7, 1, 3, 9 on the remote, then press ENTER
The info showing on that screen for the DVB-412 is:
Model: Zenith ZV8020001
Region: 1
Chip ID: M3355A-B
Servo ver: S101_43180
Microcom ver: V1.50A MP
PROM: 55 53 00 45 02 55 64 FF
Factory reset... done...
(the PROM I listed above is before the VCD/SVCD hack)
Posted on Mar 29, 2008
SOURCE: dvd player will not open disc, display lock
press eject and stop at the same time
Posted on Nov 11, 2009
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Luxor tv with dvd player was bought for me from Asda I've had problems with playback of dvds pretty much since I've had it it has a tendency to freeze and not play and on very several occasions it...
Hi Danny.
this could be a couple off things wrong here.
1,could be a faulty dvd player.
2,could do with having a lens cleaning disc put through it.
3,could be a faulty lens reader.
if i was you before i do anything big to it i would run a lens cleaning disc through it and see if it cleans the lens that reads the discs.
if this does not work i would take it back,or get someone to have a look at it for you.
Nov 04, 2017 | Televison & Video
Everytime I put a disc into my LG DVD player, it ejects the disc and the message is disc error
Dirty disk or circuit is overheated by condensation try lens cleaner several time to fix the dvd.
Dec 07, 2010 | Audio Players & Recorders
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
DVD player wont eject
Try Turning the unit off and then back on. As soon as you turn it back on push eject .
Jul 25, 2009 | Audiovox VOD102 Car DVD Player
DVD in the wrong way; won't eject
Apart from taking it apart! or forcing the disc tray out "DON'T" !!! try switching off at mains holding eject button continuosly pushed in and put mains back on, sometimes this causes a full "re-boot sequence" which from experiance and several attempts, does throw me the tray open!
May 20, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Error C:31:00
It seems this sort of problem is very common with this player. The fix I have is pick the player up, rotate it 90° give it a very light nudge, and then put it back. This has fixed the problem on mine each and every time. It will come back, but just do it again. It's probably best to put the dvd player in an easy to reach place cos you'll need to do it often once it starts making the noises and error messages.
May 16, 2008 | Sony DVP-F25 DVD Player
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Sylvania DVL-515 DVD Player Logo
53 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
