-   ELECTRIC ROPER DRYER NOT HEATING. wHEN THE DRYER WAS UNDER WARRANTY THE THERMAL FUSE WAS REPLACED TWICE THEN THE HEATING ELEMENT. tHE REPAIR MAN TOLD ME THAT THE APT.'S MAINT. SHOULD COME AND CLEAN OUT THE VENT. THE TIMER WORKS BUT IT'S JUST BLOWING COLD AIR.-   Jayde345
Nov 06, 2007
-   what if i do not read 120 across the red/white and white/black?-   k-smoove
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Our Hoover Nextra 8 switches off when the cycle reaches 70 mins left. If you turn the dial it will...
(More)
Our Hoover Nextra 8 switches off when the cycle reaches 70 mins left. If you turn the dial it will start again. In all other respects it works perfectly well. Any clues?
Whirlpool model# LEQ9558KQ1 My dryer was making a lot of noise and walking forward. I've replaced...
(More)
Whirlpool model# LEQ9558KQ1 My dryer was making a lot of noise and walking forward. I've replaced the belt and tension rollers. The parts came in a kit. However the dryer is still making a lot of noise. Is it the drum? Can it be fixed?
I have a GE gas dryer that will not heat. I can see the glow igniter come on and it seems to start...
(More)
I have a GE gas dryer that will not heat. I can see the glow igniter come on and it seems to start to heat, but it does not stay on or heat at all. What do I need to look at or to replace?
Roper elect. drier mod #ES7745RQO drier runs , no heat. not clogged, heater switch ok, pigtail o.k....
(More)
Roper elect. drier mod #ES7745RQO drier runs , no heat. not clogged, heater switch ok, pigtail o.k. fusebox ok. can i test the coil? do i neet to take it apart?
hello.. recently the timing cam came off my commercial dryer. When I tried to reattach...
(More)
hello.. recently the timing cam came off my commercial dryer. When I tried to reattach it and align the v notches, the yellow notched piece sits below the timer wheel so it doesn't advance. the drier runs endlessly. any ideas?
