Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DRUM NOT TURNING ON DRYER
DRUM WILL NOT TURN WITH A FULL LOAD
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10844419
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 • Ovens
1helpful
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Temperature is out of control for my oven. just turning the broil/bake knob onto the bake position is turning on the over and the temperature, without using the temperaqture knob reaches 400 deg !!!
The thermostat is likely bad.
Visit repairclinic.com and enter your full model # for a replacement parts list.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 • Ovens
Where does the ballbbearing go when replacing rear bearing kit on electric dryer
Without the model number it'll just be a guess but some have a ball and socket type bearing on the back center on the back of the drum.
Feb 10, 2010 • Ovens
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
2answers
Dryer barrel doesn't move on Maytag D-4 Automatic Dryer
Sounds as if the belt is gone if you remove the outer skirt you will see the motor and pully for the belt.
Nov 28, 2009 • Ovens
When i turn the oven on it come on at full power and i by turning the temperatue knob i can't adjust the flame
some units operate like that, like an electric stove, the heater turns on and off at full power to maintain selected temperature.this is normal operation a bbq you can turn the flame up or down.
Aug 09, 2009 • Ovens
7 day thermostat for multiple baseboard heaters
you will hjave to set up a relay box yourself with a transformer to supply 24v to the programmable stat if oyu want to go that way otherwise the only other option is to place the inline water heater timers to turn on and off by time only
May 28, 2008 • Ovens
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
