Question about Soyo DYLM1798 Monitor
"OUT OF RANGE"
Hello I bouht a new computer. Vista first time turn on setup goes up to the point - just before it asks you questions - chose your user name ... ... . Monitor shows [OUT OF RANGE]. The monitor does not react to any menu controls. I had to take the computer somewhere else and connect it to an older CRT monitor to continue with the setup. After that, the soyo mt-ni-dylm1798 monityor works fine. weird,,, please help. I don't want to go through this every time I restore my computer to factory settings. Thank you, Walt w.bak@ldcsb.on.ca
  • Corigador Mar 31, 2008
    I've got this same issue with my computer but not the soyo monitor. My setup has been running for 4 years with the same hardware and setup. It was very random that this error occured right now and is still going. I'm running right now on safe mode and I still don't know what is causing it. I know it is something to do with the graphics card or settings in some way but I'm not sure what. Can someone give more insight?
    To describe the issue further, it is really hard to even get to windows because the computer goes flat black after just booting it up. It doesn't even get to windows before going black, infact the message "Out of range" shows on both of my monitors right after going through the windows loading screen.
  • feeley55 Mar 13, 2009
    I changed the resolution on the monitor and now it won't display anything other than "out of range"
    Brigadier General:
  • 6,966 Answers
Hi, It is just that at the initial stage your screen resolution was a tad too high for the capacity of the monitor. As long as you retain the working resolution you should have no problem. To lower or increase, right click on any clear area of your desktop, click on properties, settings tab, adjust the Screen resolution to your preference as long as it is within the capacity of your monitor. Adjust soon as your monitor says out of range, click on escape and go back one step. click on apply and ok and this should hold till you manually change it again. It's really of just the PC trying to give its best but the monitor was not up to it. Good luck and hope this works for you. Post back how things are or should you need further information. Kind regards.
Posted on Aug 21, 2007
    Problem Solver:
  • 6 Answers
"Out Of Range" is more than just resolution. It means your video adapter is set to a resolution/refresh rate setting that is outside the range of supported signals.
Go into your Video Adapter's settings, look at resolution then the refresh rate (Hertz), and compare to those supported by the monitor.
When I had a similar problem, I noticed that somehow, the refresh rate was set at 59HZ which is unsupported. After changing to 60HZ (which is supported) the problem went away.
Posted on Nov 01, 2014
Hi check the VGA 15 pin adopter first it might resolve your problem
Posted on Apr 04, 2010
I had vista on my computer and XP on a different hard drive..... now when i boot my computer up it asks me what to boot with (even though Vista hard drive is no longer plugged in) how do i get it to just...
go to bios setup, press del at first screen and you will go to bios setup, search boot device and chose first boot device is hard drive that installed xp, and do not select the hard disk that vista is installed at second or third boot device
i hope this helpful
thank you for using fixya
Feb 16, 2011 | Microsoft Windows XP Professional SP2
Vista will not come out from sleep mode ?
Disable sleep mode. Right click the desktop any where. Chose screen saver at the bottom chose change power settings and chose change when the computer sleeps. Set to never. Just turn it off when not in use. Next; check the MS window site for a fix, there is a download update if it is still posted.
Feb 24, 2010 | Computers & Internet
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
No sound for p5pe-vm
at device manager I right click multimedia audio controller. the one with a question mark. a dialog box appeared. I selected update driver. then vista ask me: how do you want to search for driver software? I choose browse my computer. Then vista gave me two options. I chose let me pick from a list of device drivers from my computer. A dropdown appeared with a list. I browse through the dropdown. The first time I chose intel because the chipset is from intel. On the right column I chose intel (r) ac '97. It did not work.
I tried to run my support cd. Again, vista said something like compatibility issue.
Then from the drop down soundmax integrated digital audio appeared, i highligted it and click next then just follow the prompt.
Then vista install the driver. Now my computer has sound.
The solution was right under my nose.
Jul 29, 2009 | ASUS P5PE-VM Motherboard
Install older version of windows xp professional
Hello.
First do this.....
Reboot the computer and enter bios by..
When the blue DELL™ logo appears, press <F2> immediately
You might have to try this a few times since you have to be really quick,
In system setup (bios)
Set CD Drive as first device in the boot sequence. Press F10 then chose "Y" to save.
1. Put your old XP CD in and reboot.
2. After reboot if asked if you want to start on cd chose yes.
3. start Win Xp installation from your old XP cd.
4. delete partiton 1 on your C: hard drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Hope this helps.
Regards...
/Tech5508
Feb 16, 2009 | Dell Computers & Internet
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
My new PC with the new Vista Vision will not except the software that came with scanner for my Epson Perfection 1260 Model J121A.What can you do ? Sincerely Gunter !
In Vista there is a feature called UCI (user access interface ) that won't allow you to run or install system software.
To install software you need to put CD in, if it goes autorun stop it.
  • Then you click on computer ,
  • click right button of mouse on cd and chose OPEN or EXPLORE, dont double click as it will go autorun again and you'll need to stop it.
  • Locate the installer file (setup or something.exe) in the CD contents.
  • Click right button of mouse on installer file (within cd files) and chose ' run as administrator ' from drop down menu
  • Grant access to installer file whenbever required by Vista.
It should be installed normally. If you still get problems after this it is probably a faulty CD.
Jul 23, 2008 | Office Equipment & Supplies
Acer crystal eye cam
FOR WEBCAM Driver follow :
1. Downloaded the file.
2. Unzipp it to a folder on my desktop.
3. Run the "Setup.exe" file in the folder that got unzipped.
4. Go through the installer until it got to the end and then let it restart my computer.
5. Wait for computer to restart.
6. It should pop up something saying it was installing the drivers for my webcam. Wait until it was done.
7. Open the Control Panel.
8. Open the Device Manager.
9. You shoud find webcam under "Imaging Devices". It may be listed as "HP Pavilion Webcam" despite having just installed the Acer drivers.
10. Right-clicked on my webcam and chose "Update Driver Software..."
11. Chose "Browse my computer for driver software"
12. Chose "Let me pick from a list of device drivers on my computer"
13. Unchecked the "Show compatible hardware" checkbox.
14. Scrolled down to the Chicony manufacturer.
15. Chose the "Acer Crystal Eye webcam.
16. Tell it to install anyway when it asked me a question about installing that driver.
17. Wait for the driver to be installed.
18. Webcam was now listed as an Acer Crystal Eye webcam in Device Manager.
Yes, dont forget to Rate my answer :)
May 27, 2008 | Computers & Internet
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Philips Unknown Problem
hi i am arun fr india
i have big problem my pc have been this setup entry key detected enter password to unlock the system...
how to slove this problem help me .... plz >>>....
Sep 13, 2007 | Philips 190B6CB/27 19" LCD
Soyo DYLM1798 Monitor Logo
1,186 people viewed this question
Top Soyo Computers & Internet Experts
Marvin
Marvin
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
