Question about Canon i80 InkJet Printer
Waste ink absorber full
There are 7 alternate flashing green and amber lights. It said earlier that the waste absorber was full and this can't be resolved by the reset codes I've got. In the past I've been able to press resume when it gave me the ink absorber nearly full message but now, after changing the black cartridge, it's not working at all and the print head appears to be stuck. Please advise!! Thanks
  • 2 more comments
  • Yargity Aug 21, 2007
    Thanks for your help - now the printer head has unjammed which is great but for some reason the black ink cartridge isn't working. The printer is printing out every colour except black.
    Any more suggestions gratefully received!
  • chatty kathy Jan 08, 2008
    Thanks for your time. My waste ink is full. I have reset it many times and can't do this anymore. Can you tell me how to emty it or fix it. I know I will have to open the printer? This is for a canon pixma ip1500.
    Thanks,
    Kathy
  • Anonymous Jun 04, 2008
    how do I change the waste ink absorber
  • Anonymous Mar 06, 2009
    Waste ink absorber full Canon ip90
    President:
  • 1,114 Answers
Try the following procedure: 1)Turn off the printer. Press and hold the Resume/Cancel and Power buttons at the same time. 2)Release the Resume/Cancel button. (continue to hold down the power button) 3)While continuing to hold down the power button press the Resume/Cancel button 3 times then release both buttons. 4)The LED should now be green. Press the Resume/Cancel button 4 times. The led should be green. Power it off and back on and you should be good to go! Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 20, 2007
  • Greg Cann
    Greg Cann Aug 21, 2007
    I'm not sure of the design of that cartridge but there is usually a small hole in the top that gets uncovered when the wrapping is removed. If you can find it then using a straw (or just your mouth if your not fussy) blow into the cartridge until ink flows. You may want to put a paper towel over the exit when you do this! This trick has saved me countless "cleaning" cycles not to mention money. Hope it works for you.
SOURCE:
Lights flashing 7 times
Never heard of 7 flasjhes.
Five flashes = No Print Head Installed. Install or re-install.
Eight flashes = Waste ink absorber* almost full. The printer has a built-in waste ink absorber to hold the ink consumed during Print
Head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the R R ESUME/CANCEL button to clear the error so printing can continue for a while.
A longer term RESET IS possible BUT without changing the blotters, you're exposed to ink eventually running out of the printer without warning but... if you still want to continue, here are the reset instructions. Good luck!
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain lit in green.
Now press the resume button 4 times and then the power button. You've just reset the waste ink counter. Good luck. Just hope it doesn't come back to bite you!
Aug 31, 2014 | Canon PIXMA iP2000 Photo Printer
Waste ink absorber is full and need to be replace unable to print
The waste ink absorber is a pair of pads at the bottom of the printer paper path (one on each side). You can order replacement pads from a service center. Alternatively, you can resuse them. First, you need to pull the old pads (have plenty of paper towels handy). This can take nearly disassembling the printer. Then rinse the pads with running water until they are clean and then let them dry, if you want to reuse them. Once dry, reinsert them and reassemble the printer.
Next you need to reset the counter for the waste ink absorber. With the printer plugged in but off. Press and hold the Stop/Reset button then press the power button. Once the Power light is lit, press the Stop/Reset button twice while holding the Power button. Release the buttons in any order and the printer is in a service mode. With the lights Green, press and release the Stop/Reset button four times (the light will go orange and green alternately and will be green at this command). Set the counter to zero. Press the Power button to save the setting. Then turn on the printer normally.
Do not reset the counter until the waste ink absorber is cleaned/replaced, you will get ink everywhere.
Please note that the printer was designed to fail about the same time that the waste ink absorber counter hits the point that locks the unit. (ie the waste absorber doesn't get full while the unit is under warranty), the printer may have additional failures soon.
I hope this helps.
May 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Waste ink absorber is full, waste ink full, waste ink absorber, a
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
Jan 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Wastw ink absorber is full
On step 4, hit the stop/reset button 4 times to clear the waste ink error.
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E8 Waste ink absorber full, or platen waste ink absorber full
Direct Printing
E22 Carriage error
E29 EEPROM error
service mode. (Waiting for menu selection)
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
button pressing
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 11, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber is full and printer won't print
Dear caucoin,
This message appears when waste ink absorber capacity rise to about more than 95 %. To fix this problem you need reset waste ink counter and it strongly recommended that you replace waste ink absorber (integrated in print base unit). Due to complicated disassembly process i suggest you to take the printer to nearest service center. For emergency reason you may perform below procedure to reset waste ink counter:
  • Plug in power cable
  • Press POWER button while holding down RESUME/CANCEL button then release RESUME/CANCEL button (do not release POWER button)
  • Press RESUME/CANCEL button two times while holding down POWER button then release all button (printer entering service mode and light stand by in green).
  • In stand by condition, press RESUME/CANCEL button 4 times (light will flash alternately in orange & green each time the button pressed).
  • Turn off printer and turn on again.
Now your printer back to normal condition. Hope this will be useful for you and don't forget to rate me.
Regards,
Source:
Canon Inkjet Forum
Dec 10, 2008 | Canon PIXMA iP90 Mobile Printer
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
Canon i80 InkJet Printer Logo
250 people viewed this question
Clive
Clive
old marine
old marine
Ekse
