Question about Sony KDS-R50XBR1 50" HDTV
Sony KDS issues
I just replaced the lamp in this thing. The problem now is i don't get any signal once the cable line is hooked up to the cable but i do get signal when it's connected to the VHF/UHF input.
  • 81 Answers
Check your setting, you could have skipped the cable side. or edited cable out.
Posted on Apr 05, 2008
SOURCE:
I HAVE A SONY KDS-60A2000 WONT TURN ON. RED LIGHT BLINKS THREE TIMES. TRIED NEW BULB. NO DIFFERENCE
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
Mar 11, 2011 | Sony KDS-60A2000 60" HDTV
I have a Sony Wega SXRD. First issue was the
No. Could be a bad ballast this time. That is the box that energizes the gas to produce light. Bulb has no filament.
Sep 10, 2017 | Sony XL-5100 Projector Lamp for Grand WEGA...
My sony kds-r50xbr1 turns on for a second then turns right back off no red lights flash. Today I just replaced the lamp and it was working fine for about an hour but then went back to the same problem.
If you already replaced the lamp and still have the same issue, that means you will need to replace your ballast, of course there is no need in returning the lamp, since eventually you're going to need one.
Jun 30, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
Sony KDS-R50xBR1 Needs projection lamp replaced
I bought a True replacement from the PartsStore through Amazon.com and it cost me about $185, but it was a Phillips bulb and the full cartridge replacement. I went with the aftermarket bulb only replacement the first time, lasted less than a week and haven't resolved that issue yet.
Apr 06, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony Lamp Cycles Off and On
Bad lamp>replace lamp and reset timer in customer menu .Common problem with SOny.
Nov 24, 2008 | Sony KDS-60A2000 60" HDTV
No picture, but sound - Lamp shuts off and on intermittingly
Replace lamp and reset timer in customer menu.Common problem with SOny.
Jun 29, 2008 | Sony KDS-60A2000 60" HDTV
Sony KDS-R50XBR1 50" HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
