Question about Brother MFC-3240C All-In-One InkJet Printer
MFC-3240C Every time that I print a picture the printer scratches it while printing it; this only happens when printing pictures. Can you please let me know what can I do to avoid being my pictures scratch.
If you are using cheap photo paper, the ink won't dry fast enough before touching parts of the printer as the paper moves during the printing process. Solution: buy top grade photo paper which dries the ink instantly upon contact with the paper.
Posted on Mar 08, 2008
On some injects, paper dust collects under the print-head and will eventually drag across you picture or document. On most you will see a hook like drag at the end of the line where the pater was advancing and the print-head was returning. If this is the case, unplug the printer and try to carefully clean the junk out from under the print-head with a piece of pater towel maybe even very slightly moistened with water.
Posted on Jan 31, 2008
    Scholar:
  • 43 Answers
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Posted on Jan 17, 2008
SOURCE:
My Mfc 3240 Brother Printer will not Print and the readout says to get the trouble shooting and maintenance guide
When ever you get an error message like the one you are describing, there should be a numerical code with it.
Most of the time when you get an error code like this, it is a mechanical problem with the machine.
Try unplugging the power for about 5 minutes to see if that clears it out, otherwise you might as well replace it. A machine like this has been discontinued and is not worth paying for repairs.
Mar 25, 2010 | Brother MFC-3240C All-In-One InkJet...
How can I turn off the Keep Printed Documents selection?
First right click the printer icon in the SysTray (by the time usually) clear all documents.
Then pull the power cord and leave it unplugged for a few minutes, When you plug it back in the the memory in the printer should be clear.
Dec 10, 2009 | Brother MFC-3240C All-In-One InkJet...
My Brother MFC-3240C printer does not print crisp images. Colors are washed out and lines run though the images. I reinstalled the CD and no luck. Can you tell me what to fix?
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 25, 2009 | Brother MFC-3240C All-In-One InkJet...
My printer wont print even after changing ink and cleaning
When cleaning doesn't help, you need a new printhead. Around $89.00 now and then you add labor. They sell a new MFC 490 for around $120.00 with a year warranty.
Jul 01, 2009 | Brother MFC-3240C All-In-One InkJet...
I have a brother mfc 3240C. I have changed the
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Apr 23, 2009 | Brother Office Equipment & Supplies
Scanner for Brother MFC-3240C
yirabella
I need cleaning my scanner is lock no printing
Feb 14, 2008 | Brother MFC-3240C All-In-One InkJet...
Cannot scan an e-mail to send
OK I beleive you it is a valid product!!!!!!!!!!!
have you installed scanning software as well as print drivers?
Brother website get full software and driver package (under drivers) and install
Oct 01, 2007 | Brother MFC-3240C All-In-One InkJet...
Printer
Before I go into your solution I have to mention a few things first. Your printer software utility has multifunction printing capabilities. What I mean is you can print on thin paper , thick paper , and even glossy paper. I would go into your settings for your printer specifically for pictures or graphics and see what the paper thickness size is set for. Compair this to your setting for normal text printing and change your picture and graphics settings so it matches your text printing. I would also check on your printer some have a flip switch to set the printing head height. If it is selected low this could also cause scratching.
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
151 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
