If i put my ldv maxus into 5th gear i have to hold it in place to be able drive, if i remove my hand it jumps out of gear. What could be causing this?
SOURCE: lost all gear drive except 5th. i have removed the
your neutral paw is broken or the return spring on the paw is broken ...try lifting the shifter up at the front as if your changing into first then down shift you will find you can get all gears doing this
SOURCE: My Harley 883 Sportster suddenly became stuck in 5th gear.
More than likely the shifter pawl has broken. Breaking in 5th gear is kind of unusual however, they usually break between first and second.
You'll have to remove the outer primary cover to look at the shifter pawl. It's partially covered by the clutch assembly.
Testimonial: "Thankyou for your help, I have been looking at an exploded drawing of the Sportster gearbox, so I can see what you mean."
The Maxus has two Gear link cables. It could be the Yellow labelled cable is about to snap. I had the Red cable snap on me at the beginning of the 2017 and lost 1st and 2nd gears.
