hi my advent qrc430 laptop went 'pop' and now fails to charge or even switch on no led lights come on and i bought a brand new chager sand i replaced the jack, is there anything cheap and easy to fix this problem?? im thinking is either the motherboard or a capacitor which needs replacing, if so do you know where i can get either items from and whether they'd be easy enough for me to replace? any thanks in advance for any help you can give.
Dear User, There is possibility that the battery of your laptop is fully discharged. in this case if you are sure that the charger is fully functional then you have to powerup the charger and plugin to your laptop and not to power on your laptop upto 20 minutes. and after 20minutes start your laptop hopefully it will work. if problem still persist then pull out the battery and power on your laptop only on the power supply it must have to work. and after that if it dos'nt work then it is sure that there is problem in laptop,s motherboard charging circuit and consult with hardware repairing center
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
I just installed two WD caviar black Hd's on an a7n8x-e motherboard in raid 1 as a secondary drive...
(More)
I just installed two WD caviar black Hd's on an a7n8x-e motherboard in raid 1 as a secondary drive in the system; this raid is NOT the system drive; I am getting an error message that appears to be from the pci raid controller that says ''port error-aborted'' whenever the new drive is accessed. The error comes up in a dialog bog multiple times even once the drive is no longer being accessed. How do I fix this?
