Question about Samsung (SP0411N) 40 GB Hard Drive
My HDD has seen in BIOS but it can't read data
Pls. Help me My HDD can seen by BIOS but it can't read data therefore it motor still spin and hear cracking noise together. Can u help me? I use Samsumg SP0411N 40 GB 7200 rpm.
  • nes_22654 Jul 21, 2008
    it can be identified in the bios but cannot open besides it is noted with a regular crackling noise.
    have a crackling sound and could not open sp0411n
Maybe the pins on the inside are disconnected happened to my dads harddrive
Posted on Aug 20, 2007
SOURCE:
How can i open the body of my Acer External Hard drives 2.5 AH022S. because i can't open it on any of computer right now.
older post but not too old
NO PC stated at all, nor what OS you run, windows, android, what?
ah022s?
is this a new HDD ext
or from other PC with data from it.
or from this unstated PC that used to work but now now?
zero key fact stated, so no anwers possible
try all USB ports yet?>
go to (windoz) deskmanager is it seen there,
go to device manager, it must be seen there 1st ,then above.
did you drop it, if yes, boom heads crash.
the rule on all external (500GB or 1TB ?) drives
with no external Power pack on it.
is that many laptops and weak notebooks
do not have 500mA power on there USB ports
so the motor is born dead.
so plug it in, with your ear to the casing of hdd.
hear it , dead.silent.
hear it spin up (here) http://www.pcdied.com/raw/spoolupjet.mp3
hear it click madly, bad.
the MP3 is jet engine spooling but a hDD sounds the same.
just very tiny sound .
if the disk does not spin up, that means HDD is dead
or power to it is weak.
laptops with 100mA (power) USB ports are USELESS for any external hdd made. (lacking its own power pack)
what I do is buy or make my own HDD drive,
with power pack , then and ONLY then will it work on ANY PC.
Apr 06, 2018 | Acer Computers & Internet
Panasonic Portable dvd/cd player model #DVD-LS90 The player turns on and tries to read the DVD. However, it no longer spins so the DVD cannot be read.
Two possibilities:
  • the laser eye (lens) is dirty, weak or defective. The unit no longer can sense that a disc is present and therefore will not initiate servo motor engagement. Pls try cleaning;
  • the spindle motor is weak or defective. This might be of additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Panasonic Televison & Video
I Took my Compaq Presario SR1103WM into shop to have the power supply replaced. bios before power supply went out, showed my HDD present.
Hit F2 or Delete during boot up and check the HDD configuration. If the drive is not shown it may be faulty.
Oct 14, 2017 | Compaq Computers & Internet
My Intel D915GAG mobo works OK with one PATA HDD. But when I try to connect a SATA HDD mobo behaves strangely: sometimes it hangs up sometimes windows (in PATA master) won't start What I...
Intel D 925 has sata 1 controller , therefor your sata 2 or 3 drive can be malfuncton with this old controller , pls connect the jumper to sata 1 speed limit position in your hard drive near the data connector
Sep 25, 2017 | Intel D915GAV Motherboard
St3160827as seagate hdd is not detecting in bios , other new seagate hdd is working fine with the same connection(sata cable and power card) I have imp data in that hdd ,pls help me how to get data...
Turn your computer off.
Disconnect the power cord.
Disconnect all other disk-drives and CD/DVD drives, leaving only the "suspect" drive connected.
Restart your computer, and enter BIOS SETUP, and see if the drive is detected, and how it is connected (primary/secondary, master/slave).
Read the model-number and serial-number and manufacture-date on the disk's label,
and access Seagate's web-site, to check the warranty-status of the drive.
If the warranty is valid, Seagate will replace the drive, at minimal cost to you.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
Hard drive does not operate
1, switch off computer
2. remove side (usually two screws on the back held it)
3. remove and then re-insert power cable from hdd
4. remove and re-insert data cable, from hdd as well as from m/b
5. start computer and hold your fingers on the top of the affected hdd, if you feel vibrations, this meant that driver is spinning and therefore rescue can be attempted at home.
6. research and purchase hdd recovery software, follow it's instruction and save data on another medium, be it another hdd or cd's dvd's.
if there is no spin, recovery is still possible but in specialist lab and will cost more money....
always back-up your data, second hdd is much cheaper than data recovery from existing one...
Jul 27, 2010 | Maxtor Hard Drive
Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Oct 04, 2009 | Seagate Computers & Internet
Hard drive not found on my sony vaio vgn nr10e/s
Try going into the bios and changing the hhd to auto that should solve it and also look in the device maneger to see if it shows up and scan for hardware chnges i hope this helps
Oct 31, 2008 | Computers & Internet
your hard disk is failing try to do a clean reformat of your HDD
Jul 21, 2008 | Intel Motherboard
Maxtor Hard Drive Crashed and want to buy identical drive
Instead of performing surgery on the hard drive, I'd suggest an alternate solution... Download the "Get Data Back" program from www.runtime.org; there is a version for drives using the FAT32 format, and a version for drives using the NTFS format, so be sure you download the correct version for your 300GB HDD... GDB can NOT help you if the HDD is PHYSICALLY damaged; the clicking noise you've mentioned COULD mean that the drive is beginning to fail, though you might STILL be able to retrieve the data on the drive with GDB before the drive fails completely... The "Get Data Back" program is FREE to use; you will ONLY have to pay for it AFTER you know if it can retrieve any files for you. It will create a bootable floppy disk that can read ANY functional hard drive, whether or not the drive is detected or recognized by a system BIOS. Again, GDB can NOT read data from a physically defective HDD, but as long as the drive is functional, GDB will show you all the files it CAN retrieve... Once you pay for the program and enter the activation code, GBD will copy any files it has recovered to the new HDD. Keep in mind that GBD works on ANY functional HDD; GDB does NOT require the drive to be recognized by the motherboard BIOS, and does NOT require ANY operating system to be installed on the drive. GDB is self-booting; as long as the drive can spin up without disintegrating, GDB will provide a list of any recoverable files it locates on the drive. GDB works even if the File Allocation Table (for FAT32) or Master File Table (for NTFS) is corrupted or missing, so as long as the drive is readable, you have NOTHING to lose by trying to recover your data with GDB... The website is very informative, and if you have any questions not covered by the FAQ, you can call Runtime and speak to someone in Tech Support (the phone number is listed on the main webpage). If GDB can recover your files, you will be able to copy your data to your new HDD WITHOUT performing HDD brain-surgery, and WITHOUT voiding the warranty on your new HDD... If GDB can NOT recover your old files, you'll know that the old HDD is physically damaged, and you'll be no worse off than you are right now... remember that GDB is FREE to use until you KNOW for certain that it can recover your data. If GetDataBack DOESN'T work, you don't pay a dime for it; if it DOES work, you'll never want to be without it again...
Mar 17, 2007 | Maxtor USB 2.0 External Enclosure + 300GB...
Samsung (SP0411N) 40 GB Hard Drive Logo
183 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
