Question about Durabrand Portable DVD
Dvd dual screen player
The second screen on the dual player will not work. If you "play" with the wire, it works sometimes but the wire isn't designed to where you can replace it that easily. I have ordered a replacement wire and that also does not work. Please let me know if this can be resolved. Thanks.
    Problem Solver:
  • 6 Answers
It is most likely an internal connection to which the wire connects to which is the problem since it wasn't resolved with a new wire and works intermittently when jiggled. According to Walmart's warranty information, Lenoxx Electronics Corp. services this DVD player brand. Their website www.lenoxx.com confirm that assumption. I suggest contacting the company and seeing what you can find out.
Posted on Aug 22, 2007
Second screen not working for dual dvd player
see the diagram and test it:
some block inside can be defective, however tight any wires connectors inside, you must open the DVD.
if you can not do it go to the repair shopt TV for fix it
God bless you
Jul 20, 2012 | Philips Televison & Video
I have the sdvd87 dual screen portable dvd player. My second dvd player only plays sound but shows nothing on the screen how can this be fixed?
i found the problem of the video blackout of the second screen, it's the chip marked CC5R sot23-6 close to the a/v connector. it's possible to make it work without changing the IC but you won't be able to have an output or input depending what you want to do if you want to make it work as original, replace that chip and it will work again. any other questions i will come back soon
Aug 03, 2010 | Curtis SDVD8727 Player
Dual xdvd8183 screen doesnt come out
hey i have a dual xdvd 8183 and my screen doent pop out but it plays and you an see that the screen is playing inside can anyone help
May 30, 2009 | Dual Electronics XDVD8183 Car DVD Player
HOW DO I GET MY XDVD8183 DUAL DVD RADIO TO PLAY WHILE I DRIVE I`VE TRIED TO PUT IT WITH THE GROUND WIRE THAT DIDNT WORK WHAT SHOULD I DO?
Take the "e-brake" wire
Ground for 1 second
Unground for 1 second
Ground for 1 second
Basically install a toggle switch and ground it, "on/off/on" and voila.
Jan 26, 2009 | Jensen VM9510 Car DVD Player
Venturer dual screen dvd player for car
Hi and welcome to FixYa,
Initially, could be:
  • cable/connector problem;
  • 12VDC power supply/regulator;
  • monitor itself. Could be tested with another external video source and a shorter RCA to RCA cable.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 11, 2009 | Power Voice System Venturer 7" Portable...
Dual portable dvd player second screen not working
Sounds like it may be a bad linking cable or connection. Make sure you have cables inserted firmly and correctly. If possible, hook main unit to TV to be sure you are getting proper Video/Audio output.
Dec 23, 2008 | Durabrand PDV-705 Portable DVD Player
Wont play
There is no simple "at home" solution to any of these problems listed. However, Since it tries to play or at-least plays Cd's, then that will indicate that affordable repair is possible. I have already repaired several of the Dual units already. With the 7" Dual screen sets, I had to replace the laser assembly or the spinner motor (not spinning fast enough). With the 8" Dual Screen sets, I found mostly that the laser ribbon was binding up in the movement of the laser and preventing it to move to proper position. These repairs should be done by a qualified technician.
May 17, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Dual DVD VHS: DVD won't turn on
The Maganvox website has a warning about playing dual layer discs on this unit - it does not work and they don't have a fix for it yet. 1-800-605-8610 for more info
May 17, 2008 | Philips Magnavox DVD/VCR Dual Player
How do i by pass the parking brake no video
1. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
2. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
From here:
http://forum.ecoustics.com/bbs/messages/4/302701.html
Oct 09, 2007 | Dual XDVD8181 Car Video Player
Durabrand Portable DVD Logo
141 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
