Question about Canon CanoScan LiDE 70 Flatbed Scanner
Scanner won't scan
When I got the scanner I successfully scanned several old pictures that were stored in the Toolbox in files according to date. Now when I attempt to scan in either photo or pdf. it gives the message "Unable to scan:Make sure that there is enough space on the target disc". I'm not sure what the target disc is and have stored some of the files elsewhere (online)to clear space in the Toolbox. Keeps bringing up the same message no matter what part of my C Disc I try. THank you.
  • 2 more comments
  • Anonymous Nov 12, 2007
    I am having the same problem. Changing the scan resolution has no effect. I have 40Gig available on my C: drive yet it indicates not enough storage space???
  • pashley Dec 11, 2007
    I get the same problem when trying to use scanner to mail a photo.It will not scan.
  • magentanyc Mar 24, 2008
    Have the same problem, unable to scan,make sure that there is enough space in the target disk......what is a target disk,? doesn't say it anywere and I have a presentation in an hour......
  • CollinLovas Apr 11, 2008
    If you change the disk drive, it works a few times and then reverts to the same "unable to scan..." message.
I had the same error. The way I fixed it was going to C:\Documents and Settings\Administrator\Application Data\Canon (the app data folder) and I cleaned the files in all the sub folders.
That fixed it for me.
Posted on Oct 29, 2008
I had same problem. I unisntalled just the 'CanoScan Toolbox' component and reinstalled. Problem solved.
Posted on Sep 18, 2008
Mine started doing the same thing, but after a little troubleshooting I realized I had a "flashdrive" on one of my usbs I opted for removing it and BOOM! That was the culprit. After that it started scanning as usual ;)
Posted on Aug 29, 2008
  • 20 Answers
Hello, It may be possible that the error msg that you are receiving may be referring to another error. 1st thing I would try is checking the resolution, in some cases if the resolution is too high it may result with numerous issue's if your random access memory (RAM) is not sufficient enough to accommodate the resolution that you attempting to scan with. Try reducing the resolution, also try a different file type, either jpeg or tiff etc..,if all failes check to see if you have the latest driver(s) update for your scanner.
Posted on Aug 24, 2007
SOURCE:
I download XP driver for N1240U from Canon. Everything seems to work including successful diagnostics check. But, when I try to scan using Toolbox, I get a TWAIN error message. My file system is NTFS....
scan with adob photoshop /import - from - your scaner device/ , it will be correctly, maybe toolbox not working normally, if with photoshop will not be resaults, in control panel \ in scaner and imaging devices see is there your scanner, if it will not be in there, reinstall driver.
Jun 01, 2011 | Canon CanoScan N1240U Flatbed Scanner
Re CanoScan 9950F: I opened Toolbox (v. 4.9.3.4), selected Scan setting "auto mode". Under "Save Scanned Image", I ttyped in a "File Name" , Saved it as JPEG/Exif, For...
Hello
Actually you do have to select a program for working with photographs such as Photoshop, or Adobe Elements, maybe Microsoft Paint or Picasa maybe. Then your scanner will scan and the pictures will be saved and they'll be opened in the photo program you have chosen afterwards.
Jan 04, 2011 | Canon CanoScan 9950F Flatbed Scanner
When I try to scan with my canonscan lide 70 I get a message "specify the program where the scanned image is transferred"
You just need to point the program to where the scanning program was installed. If you just let it auto-load it should be here: (assuming you loaded the free toolbox software)
C:\Program Files\Canon\CanoScan Toolbox Ver5.0\CSTBox.exe
or just look at where the toolbox is installed by searching for the CSTBox.exe file.
Mar 06, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Hp 3670 no longer scans to computer with vista 32 bit upgrade. Scanner will only scan out copies to printer. worked fine with windows xp
You can use Paint or a similar program to scan in a picture/document with your scanner.
Once in Paint you can select from Open the option of From Scanner.
You can change the size to fit the page in Paint and then save it to a file which can be opened and sent to a printer.
It's very basic, of course and it doesn't give you the options to set the scanner options usually found in the HP Toolbox.
Jan 31, 2010 | HP ScanJet 3670 Flatbed Scanner
Can not scan. keep receiving message "unable to open file".
try to reset the file link (toolbox CS -> settinf -> save -> image file) where the scanned file will be saved.
Apr 16, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Trying to make a copy- worked last week?
This is most likely only happening when attempting to scan through the CanoScan Toolbox. You can scan directly through ArcSoft PhotoStudio which came with the scanner. However, the error through Toolbox is likely caused by some limitation or restriction in the computer, possibly permissions of some sort. You may try deleting temp files from the Temp folder on the hard drive.
Jul 15, 2008 | Canon CanoScan 4400F Flatbed Scanner
CanoScan LiDE 50, error code:2,7,0
When you say the error occurs as soon as you press "Scan", is that the button on the scanner, or is it the Scan button inside of Toolbox or ScanGear?
If it is the one on the scanner, try accessing the driver through an application such as Toolbox. If you didn't download that when you got the driver, then go back to the Canon download page and download & install the CanoScan Toolbox. Once that's installed, lauch Toolbox from Start|All Programs|Canon|....look for Toolbox from here. Once you have Toolbox open, click the 'Save' option. Next, check the box that indicates to Use the scanner driver. Click the Scan button at the bottom. This should open ScanGear. Attempt to Preview scan.
May 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Will not scan photos, only slides
Where are you scanning from? Do you get an error? If scanning from Toolbox, check the box that says to use ScanGear or use the Scanner driver. Then make sure it is not set for Film as the select source.
May 05, 2008 | Canon CanoScan 8600F Flatbed Scanner
Canon 440f won't scan
I had exactly as described on my new 4400f scanner. Have resolved by uninstalling the toolbox software (it was at 5.0.1.2), downloading toolbox s/w from canon site, file name is S6A04mux.exe - toolbox 5.0.1.1 Installed this and all works from the scanner front panel
Jan 06, 2008 | Canon CanoScan 4400f MultiFunction Color...
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
613 people viewed this question
Clive
Clive
old marine
old marine
