Question about Akai LCT3201AD 32 in. LCD Television
Remote Controll Sent the remote that came with it back, got a new one from mfg. it also does not work. Any ideas.
  • 398 Answers
If the original remote is working but the set does not respond, it usually means that the little remote sensor (the IR "eye") inside the set has stopped working and needs to be replaced. I have been seeing a lot of those little eyes bad lately. If the set is still under warranty, the manufacturer should take care of it, but if it is out of warranty then have a qualified tech replace it for you.
Posted on Aug 22, 2007
SOURCE:
Is there a way to take remote controll off of a fan mine stoped working after kids pulled fan or light pull
My ceiling fan loses remote control every time there is a power outage. The first thing to do is turn off power to the fan at the circuit breaker. Take the battery out of the remote and push all the buttons to eliminate a stuck button as a possible cause. Reinstall the battery. Turn on power to the fan. Check operation. You may have to pull a chain to "reeducate" the remote but you should be back up and running soon.
Dec 31, 2012 | Hunter 52" Ceiling Fan With Light And...
I having problem with my remote controll working on my TV i thought its was the battery but i change them and now its not working at all nor the cable remote
take down your remote and clean it with regular alcohol.then set it up back.if that does not correct your problem.you will need to buy a new remote control.check partstore.com they will have remote for your tv .good luck.
Feb 28, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Do i need to program the remote for a procom ventfree fire place
the owners manual for the remote/unit should be able to walk you through the steps to program it.
Feb 15, 2009 | Heating & Cooling
REMOTE CONTROL FOR SUNIA LTD 1510 lcd tv/dvd PLAYER NOT WORKING
Hi there...
I purchased a new Malata 19", I do not know if the controls are compatibles, but they should be... I recommend you purchase a learner control remote and I can help you program it from my remote control... I know it sounds crazy, but that is the way that I had solved those kinds of problem before...
If interested, send email to [email protected]
Apr 25, 2008 | Wanlida Group LCD Television/progressive...
Goldstar tv remote codes
GoldStar TV 0030 0178 0019
Mar 05, 2008 | Televison & Video
Codes are not working
did you mean remote controll?
if you mean remote controll the common trouble of remote controlls is only three
1) the IR LED /infrared led
2) dirty contacts of keypad
3) leaky/open/shorted capacitor
Jan 05, 2008 | Toshiba 32AF43 32" TV
Code for remote control
was the tv function working before or not as sometimes the controll will only work certain tv if it did work before is it a controll that can be programmed to work different appliances or not let me know and if you need the code for the remote i will try and get them for you post back and let me know the make and model of ctrl and make and model of the telly you want to programme the controll for ...............................
Nov 17, 2007 | Televison & Video
Wii remote controll
Buy a new sensor bar. None of my 5 Wii remotes had a cursor on screen so I bought a new sensor bar and it worked fine.
Nov 12, 2007 | Nintendo NES Remote Control
Casio Remote will not work with NEW batteries.
the plug on the side of telly is for a cable remote which you can buy but these are pretty useless it sounds like the controll has got damp or has got greay if you think you can take the controll apart without damaging it then i sugest take the case off and clean behind the buttons this is usually the problem wipe the pads on the buttons then get some cloth that is clean then wipe over the circuit check for water damage then put it back together if this dont still work then you will need new controll as the originall are expensive to buy the best thing to do is buy an all in one remote this should solve your problem hope this is some help for you...........................
Oct 30, 2007 | Casio EV-1000 10.4 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
43 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
