Question about Canon PowerShot S2 IS Digital Camera
Lens not moving - Canon PowerShot S2 IS Digital Camera
Send to the service center, this is probably related to the lenses drive train step motor or the step motor position sensor. If it does not work, buy a S3. Good luck.
Posted on Sep 21, 2007
"E212" Lens problem (sensor, motor)
You have a very old copier..... Try taking the copy board glass off and the lens cover (black box) off. Try to move the lens with your hand, will it move? Move it out of HP and turn the power ON. Will the lens move, if so look where it stops.... I believe there is a drive gear that may of cracked... You have to watch were it stop moving....Good Luck
Jan 15, 2013 | Canon NP 6050 Copier
Motor whirring but not moving lens on pentax ist d
The lens pins either broke or maybe out of position and not moving the lens..
Here is a tip that I wrote about How to get a Digital Camera Lens to work again
Steps to Repair a Digital Camera Lens
heatman101
May 13, 2011 | Pentax *ist DL Digital Camera
Lens is not opening
Take the lens out and look the bottom side of the lens. There is a lever that operates the aperture leaves. If the aperture leaves does not move or moving slow, you have oils on the aperture leaves which need cleaning.
If the lens is good, the camera's lever that move;s this lens' lever mechanism had gone bad. Take out the lens and watch the aperture control lever moves when you trip the shutter. If it is moving, the problem is with the lens.
May 18, 2010 | Minolta Maxxum 7000 35mm SLR Camera
.bnklghl;
The lens can move in and out in straight line. If, due to the hit the lens casing got bent then it will stop moving. The glass may be fine but the casing seems to have taken a dent and is touching the sides somewhere. And to zoom in or out the lens have to move in and out. Try to get the lens in the middle of the lens well. Try to pull it out when powering on.
Nov 30, 2009 | Casio Exilim EX-Z750 Digital Camera
Lens is stuck out
Chanches are the lens received impact damage or there is some dirt, liquid like pop that is blocking your lens from moving. Try moving the lens and see if this will dislodge the lens. View the lens from top and sides, if it is sitting on an angle it has received impact damage.
Jul 02, 2009 | Olympus FE-270 Digital Camera
Lens does not move manually
You should not try to manually retract lens because lens has few gears in loading mechanism that can be broke if you put some force in try to rotate on lens.
Feb 10, 2009 | Canon PowerShot A550 Digital Camera
Unable to load playstation dics or any other discs for that matter
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 05, 2008 | Sony PlayStation 2 (PS2) Console
Aperture diaphram on mamiya secor lens 80mm f/2.8
The lens has a lever marked A/M near the aperture ring. If the lever is in the 'A' position, the lens will stay wide open until you trip the control lever at the back of the lens next to the rear optics. In the 'M' setting, you can see the aperture move as you change the f-stop setting on the ring. Set the lens to anything but wide open and move the control lever with your finger. You should see that aperture move.
Jan 14, 2008 | Photography
DSC-w70 stuck lens
there actually is a little gear inside that moves the lens and since you already opened it make sure the gear is there and moves. LOTS of problems with these cameras....
Jul 30, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
