Question about HP P5302M Computer Speakers
Speaker problem i recently bought an hp a6100y desktop computer, and i have managed to get everything installed, but i can't get sound to come out of my speakers. i've plugged headphones into the port and sound comes out, and i've checked the volume and hardware set-up and it says the speakers are working.
  • Kate Kane Feb 23, 2008
    I have same issue however I know there should be nothing wrong with my speakers...I have just replaced my computer and my speakers worked just fine with the last computer. My issue is I cannot disable the sound from the tower and I cannot get sound from my speakers ... my PC says my speakers are working.
    Brigadier General:
  • 6,966 Answers
Hi, Assuming that the speaker is plug in to the PC and power is also applied to the speaker - If the PC sounds comes out of the headset but not on the speakers, then the speakers are defective. Being new/recently bought, your best course of action would be to bring the unit back for replacement or at least the speakers since trying to repair it would void the warranty. Please remember to bring proof of purchase, warranty card or whatever document(s) are required for this sort of complaint. Good luck and kind regards.
Posted on Aug 21, 2007
SOURCE:
Lost sound after installing windows 7 on my hp d530 sff pc
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps.
Jan 02, 2013 | HP Compaq d530 SFF PC Desktop
I just bought a computer and the first day the speaker was working fine and now i cant hear any volume i checked everything making sure its not in mute
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 28, 2010 | HP (PP036AA) Computer Speakers
There is a sound problem. i installed window xp recently , after that i installed drivers everything is done but sound driver is not performing so please tell me solution right now
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or scroll to sytem speaker right click select properties you will see at the bottom use this device enable/disable this device
hope this helps
Nov 26, 2010 | AMD Sempron 2800+, 1.6 GHz (G54222)
I had a virus and had to remove everything off the computer than reload everything again and now I have no sound - how can I get the sound back on my computer?
hope this helps
Nov 07, 2010 | Dell Dimension 4700C PC Desktop
Recently was not able to hear sound on my computer. Have checked all the basics
My 2cents.
1. Check volume control (Mute, device selection etc)
2. Restart the computer.
3. Try using another speaker.
4. Check the device condition at device manager.
5. Try re-installing the driver, shouldn't hurt trying.
6. Check the cables in your desktop. You should be able to find a guide on the connections of your desktop.
7. Replace sound card if all doesn't work.
Dec 07, 2009 | HP Compaq Presario SR2150NX PC Desktop
I recently put a headset for calling and it worked good but after i unplug it my computer has no sound at all..tried doing a system restore but it did not help at all. how do i fix this problem for my...
Hello virac80,
Does your HP desktop have a built in speaker or is it connected to an external speaker system?
You could also check if the audio jack is properly connected to the audio port at the back end of the desktop itself.
Just to be really sure, you can go to your Device Manager & check if your sound card is working fine.
For you to get to Device Manager, click on the Start Menu button, then drag your mouse cursor on top of your My Computer icon, right click that icon then go to Properties.
Choose the Hardware Tab, then choose Device Manager.
Find Sounds, Video & Game controllers. If you don't see any red X mark or exclamation point, everything's okay.
Just double check on your wires if they're all properly plugged in to the correct ports.
Nov 20, 2009 | HP Pavilion A6120N PC Desktop
My speakers
is the drive for the speakers installed?
Check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Have the driver ready for the sound card by either a driver disk or by downloading the driver from the manufacturer website. This would be Dell, gateway, HP if you bought a name brand PC.
If this does not help, I need more details about your computer such as Vender, motherboard, and dedicated sound card if applicable.
Feb 28, 2009 | E-Machines eMachines Desktop PC
Dell GX280 speaker problem..??
Go into the device manager and see if the sound card drivers are installed. If not then you'll need to install the drivers for them.
Feb 06, 2009 | Dell OptiPlex GX280 PC Desktop
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
Harmon/kardon speaker problems
Go to device manager and see if they are listed.
If there is a yellow or red mark there the driver needs reinstalling or installing
Dec 26, 2007 | HP Pavillion a818n Desktop PC (Refurb)...
HP P5302M Computer Speakers Logo
210 people viewed this question
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
