Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Problem my monitor flickers it system restarts continously it gets up to check disk then shuts down & starts again it happens nearly 10 -12 times then windows loads after that screen flickers just tell me what the problem is
  • 63 Answers
If it is going to CHKDSK then you may have an issue with your Hard Drive. Going directly to Check Disk could mean that the system cannot see the boot sector of the HD. Try reinstalling the OS, if that does not help, you will probably need to change the HD. Good luck.
Posted on Aug 21, 2007
    Problem Solver:
  • 9 Answers
Most likely you have a virus or worm. Do you use any Virus program? Can you download the latest updates (virus information) for the program and scan the whole system. Eliminate all threads. If the issue persists, I'd try to boot from a CD, for example a Linux Live CD like Ubuntu and run memetest. If the system is still unstable, it should be hardware issues. K<o> Busy, supporting non technical users of Open Office
SOURCE:
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
I have a compaq laptop CQ 40. the display screen is flickering continously after i have loged in . please help me.
reinstall video driver and restart the system. if possible, try connecting the computer on an external monitor and check if the display also flickers on the ext monitor.
Dec 01, 2009 | Computers & Internet
When i power down my notebook, windows is not shutting down completely which causes a long power up. it came pre-installed. when i turn my computer back on, a screen appears stating windows did not...
First, run a scan disk/check disk option. You usually get prompted for this upon a reboot.
Second, if that doesn't work, windows is smart enough to create a few restore points when new drivers/updates are installed. Open up an explorer window (like my computer or my documents, not internet explorer) and press F1 for the help display. Search for system restore. It's very user friendly, so it should be pretty easy to find it
Jun 11, 2009 | Microsoft Windows Vista Ultimate Edition
My pc is restarting automatically continously when i turn on my
Does it show BLUE Screen, or does it show the Windows loading before it restarts?
If Bluescreen, something happened to root system files and you need to REPAIR
1. Shut down PC, pull out all USB devices, Floppies and insert Win CDROM
2. Power on
3. Press any key to boot from CDROM
4. Select Install
5. Select Repair
6. Ans questions and let run 30min
7. Remove CDROM
8. Reboot - it should work now
If Windows Logo, A device or driver you or MS or Mozilla or... installed for you malfunctioned and you need to start in LAST KNOWN GOOD mode
1. Reboot
2. Press F8 and hold down
3. Enter Password if asked
4. Select "Last Known Good"
5. When stable and logged in, Reboot
Jan 18, 2009 | Microsoft Windows XP Home Edition
Turns on, then shuts down before anything shows on monitor
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Auto Adjust
I have found a way to stop flickering of auto adjust - press the menu key on your monitor -factory reset-menu button-all settings. That has solved my problem and hope it helps you.
Sep 04, 2007 | ASUS VW192S Monitor
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
