Question about Sanyo DP26746 26 in. LCD Television
Torn LCD The TV has a damaged LCD, can the LCD be replaced, if so where can we obtain one.
    Problem Solver:
  • 19 Answers
Lcd can be replaced,but it would cost more then buying a new tv.
Posted on Sep 17, 2007
SOURCE:
No picture no power kids pushed it off the dresser
Ouch. If you are lucky unplug double check cord connection at back. No help? Wire at plug end may have torn in the fall. Wiggle wire at the plug end if you get something the cord needs to be replaced. Otherwise, you may have major damage. A lightly used replacement may be less than a repair.
Mar 06, 2015 | Sansui HDLCD1908 19 in. LCD TV
Looking for screen replacement for LG LCD model 42LK450
You could try disassembling it, because in most cases on lcds there is the very delicate actual panel, and then a thin piece of protective plastic. If there is, you can simply replace that. It all depends on whether the lcd itself is damaged.
However,
Without more information, it's difficult to tell how hard it'll be to do. It can also be quite expensive (usually around the original cost of the TV for a new replacement screen). If you have a LCD projector set, that too can be quite expensive unless you're able to obtain a rebuilt unit somewhere.
I would recommend selling the parts on ebay.
Sep 20, 2011 | LG 42LC2D 42 in. LCD HDTV
My 37 inch olevia flat screen has a punicture spot in the screen can this be repaired or replaced?
Replaced buy another tv.This tv can't be repair,if damages or broken to the LCD screen panel,only can be replacing a whole new LCD screen panel,will cost the same as a new tv.Damage tv tries take it aparts and savalges save parts for the same tv and model u going to buy.
Feb 10, 2011 | Olevia 237T 37 in. LCD TV
Screen is damaged how much is a new screen and where can it be got from please, thanks
A new LCD or plasma screen can only be obtained from the factory but it will cost you almost as much as a whole new tv to replace it. Just junk this tv and buy a new one
Aug 30, 2010 | Televison & Video
Tv screen dinted
The panel has been damaged, at the least.
The panel Part # 1-802-059-32, cost approx $1,602.95
Knowledge obtain from: Repair experience on same symptom.
Parts reference: http://www.partstore.com/SearchResults.aspx?q=1-802-059-32&x=24&y=10
May 01, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a torn screen are there any replacement parts for my toshiba 42WH46 42" rear proejection tv
If the panel is damaged it is not worth fixing. In some models, you may be able to replace the outer glass, If the TV still shows a good picture and only the glass, that is on the top of the panel is damaged.
Best of luck
Nour BMI
Feb 12, 2010 | Toshiba Televison & Video
Damage on the back of my ds
Your cable is destroyed. It will have to be repaired. Look online for VIDEOS on how to replace the top lcd. It requires rolling of the top lcd to fit into a small hole and I've torn a number of those my first time. Good thing it wasn't my money I was spending ;)
Look on Amazon and you can get top lcds for under $20.00!
Any more questions, good luck
May 29, 2009 | Nintendo DS Lite
Broken screen
It can but, it's about 75% the cost of a new tv and it isn't just a pop it in type of repair. It it quite exacting. Getting just a new screen is a challenge in itself.
Jan 12, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Sony bravia 32inch lcd tv
No longer needed, not now having this tv
Dec 28, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sanyo DP26746 26 in. LCD Television Logo
49 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
